Airbrushing problems
Posted by Anonymous on Thursday, May 22, 2003 5:57 PM
I just started using my airbrush for the first time , and i had some problems. I couldn't get the paint to stick nicely, and the air from the airbrush would blow circles in the paint. I found that the problem was that the paint was thinned too much. I gixed an still hav some questions. 1- my paint is coming out really dark, for instance, the dark green looks almost black( by the way, im using Tamiya paints thinned with 70% isopropyl alchol)
2- I get little sprits of paint near the areas wher im airbrushing. The little dots are giving me alot of trouble, but its mainly get the paint to come out even and with the right color thats really killing me. Could anyone maybe give me some hints or pointers on what to do? I would be most thankful. ANY AND ALL COMMENTS ARE WELCOME
Posted by Moses on Thursday, May 22, 2003 6:13 PM
Ok, I had similar problems when I first started airbrushing. I use Tamiya Acrylics almost exclusively and I only thin the paint with either Tamiya Thinner X-20 or 90% isopropyl alchohol. I use a double action Badger 150 bottom feed, and I get my best consistency by thinning my paint on a 1:1 ratio (paint to thinner) at a psi of between 25-30. Keep an adequate distance for basecoating and do not exceed 30 psi in my opinion when basecoating. Always practice on a piece of styrne or plastic. I find using cardboard will only absorb the paint and not give a true color or consistency. If you are doing camo patterns you can thin the paint a little more and spsray at a higher psi, no more then 35 (again in my opinion.) Thosecircles your getting is because your not moving the airbrush at a steady consistent rate. To thinned paint sprayed atthe same location point to long will cause it to build up at the edges. Also make sure you mix your paints enough before adding the thinner and then mix again. You might not be mixing your paint enough, and that could be causing it to appear to dark. Priming a model in white or light grey will give a much better color tone to your basecoat. As for the little dots, it is definately from one of two reasons. One, Acrylics dry fast and you have to make sure your tip does not have dried paint on it. If it does it will case splatter or stippling on the paint. Just dip a cotton swab in thinner and dap the end of the airbrush. another reason for the dots could be that your paint is to think, and comes out of the airbrush in a sort of clumpish fashion. In a nut shell, make sure the paint is thin enough for a nice consistent spray, make sure you mix the paint, make sure the tip of the airbrush does not have dried paint on it, move the airbrush in a steady fashion (not staying in one location point for to long, gradual spraying and building up of the basecaot is better then giving it one big coat), and making sure your not to close to the model, and spraying at a strong enough psi. This is all my opinion and what I do when airbrushing. Hope it helps.
"ZIM FIRST, ASK QUESTIONS LATER!!"
