Academy 1/35th panzer IV H
Posted by Anonymous on Thursday, January 27, 2005 6:26 AM
hey guys,
by any chance would anybody have this kit and could anyone scan me the instructions for it please because a mate of mine give me this kit he had but there isnt any instruction.
So please if anybody can scan them and send them to r8_clubby05@hotmail.com
thanks you so much in advance Az
    April 2004
Posted by pmm736 on Thursday, January 27, 2005 8:13 AM
What is the kit number? I have the Pz IV H/J but I don't know if it's the same kit.
Posted by JWest21 on Thursday, January 27, 2005 2:55 PM
I might have it, but I will have to check this evening. I have an OLD Academy kit that is downstairs someplace
Jason "There is a very fine line between "hobby" and "mental illness." -D. Barry
Posted by JWest21 on Thursday, January 27, 2005 5:41 PM
I have the H/J kit 1328. Not sure if that is quite what you are looking for, but if so I would be happy to either scan them or snail mail them (my scanner tends to make LARGE files, so regular mail might be better, but your choice). Let me know here or e-mail me if they are wha you need
Posted by Anonymous on Friday, January 28, 2005 5:11 AM
thanks guys, the kit number is 1327, so id be extremely greatful for ur help
    April 2004
Posted by pmm736 on Friday, January 28, 2005 7:38 AM
Mine is the same one as Jason's.
Posted by Anonymous on Friday, January 28, 2005 8:00 AM
thanks anyhow pmm736 it doesnt matter if noone has it ive got other kits to keep me busy so thanks anyhow
Posted by JWest21 on Friday, January 28, 2005 9:08 AM
Did you want what I had?
Posted by Anonymous on Saturday, January 29, 2005 5:22 AM
ok if its no trouble jwest21 thanks for ur help bud could u email it to me please at r8_clubby05@hotmail.com
    January 2011
Posted by Chazzer on Wednesday, March 2, 2011 9:16 AM
I was doing research and happened across your post. I just started building the same academy kit. Do you remember the built? , I'm finding the kit to be somewhat of a pain in the a@#. Would appreciate any pointers. Thanks.
ChazzerBlack Eye
Posted by tigerman on Wednesday, March 2, 2011 11:31 AM
I haven't seen those guys on the boards for a long, long time.
 Eric
    January 2011
Posted by Chazzer on Wednesday, March 2, 2011 4:30 PM
 Tank 1 T(h)anks Tigerman
ChazzerBlack Eye
    August 2005
Posted by Phil_H on Wednesday, March 2, 2011 9:33 PM
Chazzer
It's pretty straightforward, but it definitely requires patience and it helps if you have shares in sandpaper and filler manufacturing companies.
Areas to watch:
  • Alignment and shaping of the turret schurzen,as this is made up from multiple parts. Alignment of the mounting brackets is a bit awkward too. It helps to have three hands when you get to this point.
  • If you build the kit straight from the box, you may find that the fender side hooks for the schurzen won't fit in the little brackets on the plates. You may have to do some strategic thinning of the hooks and brackets or consider replacing them with thin styrene strip.
  • the hull-side schurzen plates themselves are extremely thick and could do with replacement using suitable thickness styrene sheet.
  • There's no positive mounting for the turret bin and you have to eyeball the amount of stand-off from the rear of the turret. It helps to add a stand-off on the underside of the turret bin using a scrap of styrene strip, as otherwise, it's just hanging from the two side brackets which in turn are simply butt-jointed to the rear of the turret.
  • There is a sizeable gap between the rear edge of the engine bay doors and the upper rear hull plate. Insert a suitably sized strip of styrene and filler if necessary.
With a  bit of work and a bit of patience, it can be made to look relatively nice OOB.
    July 2004
Posted by stikpusher on Wednesday, March 2, 2011 9:38 PM
It's just a clone of the old Tamiya Mk IVH kit. And yes it can be build in to a nice kit. A great entry level kit to build up and have fun with.
Looking at the original poster's history. He hasn't posted here in almost 6 years here..last one in Oct 2005...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2011
Posted by Chazzer on Saturday, March 5, 2011 8:55 PM
  Downing Shots         Yer right about the sandpaper and fillerVomit Into The Toilet. Holy smokesAfraid. LOTS of filling and sanding!! Your pictures helped out a lotThanks. This build is gonna take a bit more time than I thoughtWaiting. I just finished a Dragon kit, 3cm Flak 38, What a difference in qualityWay Too Happy! Academy's plastic is much more softer and with varying thickness and a lot of flash to clean upPulling My Hair Out. Like you said with just a bit of work Knifeand a bit of patience.....or notFlamethrower
ChazzerBlack Eye
