Weathering armor
Weathering armor
Posted by Anonymous on Tuesday, June 3, 2003 3:25 PM
Ho ho ho fellow people! Just wondering if any considerate geezer would like to share some tips on weathering tracks on armorCool [8D]
Cheers
Posted by Anonymous on Tuesday, June 3, 2003 3:52 PM
1: Paint tracks gun metal
2: Wash with rusty-brown
3: Drybrush lightly with gun metal
4: Use a soft pencil and, er, dry pencil for that true metallic look..
    January 2003
Posted by shermanfreak on Tuesday, June 3, 2003 9:15 PM
My method is really quite close to Michael's
1) Paint tracks with gun metal
2) Dry brush with rust
3) Drybrush lightly with steel
4) Burnish all metal surfaces with pencil lead
5) Complete weathering with a dusting of pastels with the rest of the kit
This method works really well for all steel tracks like that found on the Tiger / Panther. If you are building a vehicle with rubber pads just paint that part of it in black, don't drybrush or burnish this part of the track and move to the dusting of pastels.
Hope this helps.
Posted by Anonymous on Wednesday, June 4, 2003 4:13 AM
Agh! Upstaged again!
I knew I forgot something..
Posted by Anonymous on Wednesday, June 4, 2003 7:41 AM
Hey thanks for the tips guys, i didn't realise how efficient you people are.Wink [;)]
Posted by Moses on Wednesday, June 4, 2003 8:43 AM
I paint my tracks in 2 different ways depending on the theater. I paint them either in Gun Metal, or a mixr\ture of black and flat earth. I will then give a hevy wash of burnt sienna and vandike brown oil paints, then dry brush in rust and steel. Then, if necessary, use rust colored pastels.
"ZIM FIRST, ASK QUESTIONS LATER!!"
Posted by Anonymous on Wednesday, June 4, 2003 11:40 AM
I actually posted this reply on another string a while back. My cousin is a mechanic in the 3PPCLI here in Canada, and he has worked on the C2 Leo tanks Canada uses. He saw one of my armor pieces, and told me this:
A) the tracks don't really rust; constant movement and the abrasive effects of sand and dust pretty much keep it wore off.
B) rubber pads are constantly pitted and such by objects on the ground. Don't know quite how to replicate that.
Those are my guidelines to painting tracks.
Posted by Anonymous on Wednesday, June 4, 2003 1:31 PM
Maybe a slightly heated pin to get the pits in the rubber pads. Go in at diffrent angles and widths to get a vareation? Just a guess
    May 2003
Posted by Build22 on Wednesday, June 4, 2003 5:07 PM
I agree with Cader. If you look at bulldozer tracks, the metal is always silver in color (dry brush would accomplish this) because the color is worn off. When a bulldozer is new the tracks are always painted yellow (to match the dozer)and the color wears off. A tank or bulldozer with rusty tracks would indicate an inactive piece of machinery. Rust accent wouln't hurt.
Jim [IMG]
Posted by Anonymous on Wednesday, June 4, 2003 5:14 PM
i paint the whole track rusty brown/black and drybrush the highlights with polished steel. i only depict rust on the tracks where they would not come into contact with the ground....and my rusty colours i tend to keep on the brown side of rust red..unless depicting new rust.
Posted by renarts on Wednesday, June 4, 2003 5:17 PM
You can give the hard rubber pads of tracks and road wheels a "road used" look with the tip of a #11 xacto blade. Scrapes, gouges and surface damage is replicatred fairly well and pops after dry brushing. You will see damage more on the edges than in the center, but it happens there too.
Go to your local DIY and look at the cart wheels on the big lumber carts and on the forklifts. The actual Shermans I've seen have similar damage.
