Help with Tracks
Help with Tracks
Posted by Anonymous on Wednesday, June 4, 2003 1:26 PM
Ok I am in the final stages of my Tamiya King Tiger assembly. I am in the process of painting and decaling. My biggest problem though is the treads. They do not fit together properly. Yes they are the vinyl ones included in the kit. The section that you link together does not fit well and on a dry fit onto the chassis they were pulling apart. I need despret help. I would like some suggestions as well as names of after market treads, metal is preferable, or plastic. Also a tip on how to correct the vinyl tread problem. Any help would be useful. By the way this is my first german tank model. I plan to post pics of this one as well as my "Honey" diorama and my completed Sherman.
The bigguy
Posted by Rob Gronovius on Wednesday, June 4, 2003 1:47 PM
Tamiya makes a reasonably priced set of single link tracks for their King Tiger. It is set #35165, but is not designed to be used with their original Hunting Tiger or King Tiger, just their newer kits. You can tell what kit you have by looking at the inner surface of the tracks. If they are smooth, you have the old type. If they have detail, then you have the newer kit.
Posted by Anonymous on Wednesday, June 4, 2003 2:07 PM
Big Guy, there are several options. As the Major points out, Tamiya themselves make a single-link aftermarket set. I can't speak to their quality, but one assumes they are good.
Ones I am more familiar with are the Friulmodel ones and the modelkasten ones. Friul is metal, modelkasten is plastic. The MK treads are put together by poking a little pin into the side of each link, whereas with friul, you slip a wire through the entire link and it holds the two links together.
There, that wasn't at all confusing, was it?
These things are expensive. They look tres cool though. They are a king tiger-sized pain in the butt to put together, don't let anyone fool you. Not that it's hard, but it is very, very time consuming. I've also had the modelkasten treads pull apartwhile you are working on a length of them, which will ruin your day!
The good part, as I said, is that they look so very cool. Another good thing is that they are available in transport mode, and you can get the later single type treads for the really late Tiger IIs as well. I think the modelkasten links themselves look just ever so slightly better than the Friul, but for me it's more than compensated by the incredible hang-look of the heavy metal Friul treads. I use Friul for that, and because they are sturdier.
Here's a place to get the Friul treads cheep cheep, as the small bird was ruimored to say:
http://www.discountmodels.com/fruil_tracks.htm
Haven't used MK since I had a frustrating experience with a Panzer III a few years back, so don't have a ready suggestion for a retailer. Anyone?
EDIT: oh, one more thing. Sometimes the kit sprockets don't work with the fancy pants single link treads, so the links box will sometimes include a sprocket. You may have to yank the kit sprocket off. I'm sure that makes you very happy to hear, but IMO it's worth all the work and the dough.
Live long and prosper,
Larry
