Glueing vinyl tracks
Posted by Anonymous on Friday, June 13, 2003 10:33 PM
Help!!! I am in the process of building a Tauro 1/35 scale A7V with individual vinyl track links connected by half-a-million wire pins. Some of the track links are poorly molded and will not support the connecting pins. I tried glueing with liquid cement but it didn't hold. Can anyone tell me of any type of glue that will adhere to vinyl...or a better way to connect the links.
Thanks,
M. Wilden
Posted by Anonymous on Friday, June 13, 2003 10:40 PM
Super Glue or a good CA should hold it, if you use the pins as well as a kind of "backbone" to the links.
demono69
    January 2003
Posted by shermanfreak on Friday, June 13, 2003 11:43 PM
Demono's suggestion of CA glue should do the trick just fine. I'm not familiar with these particular tracks, but they do sound a little tough.
Posted by Moses on Saturday, June 14, 2003 12:05 AM
Wow individually linked vinyl tracks. Like Rob said, I am not familiar with those types of tracks, but as teh above said CA glue will hold them.
Rob
"ZIM FIRST, ASK QUESTIONS LATER!!"
Posted by Anonymous on Saturday, June 14, 2003 12:23 AM
I also am not familiar with those tracks but I must agree with those above.
Super glue,zap a gap,loctite 401,are all good ca glues to use.
I also would reccomend that you find some ca debonder if you are going to be using it on such small items.
You should be able to find it at any good hobby shops.
It comes in handy when using ca glues and keeps you from getting stuck to your work.
Test it out on a small piece first because it is kinda harsh and could kill your plastic if your not careful.
Good luck.
Posted by djmodels1999 on Saturday, June 14, 2003 2:43 AM
Stapple both ends together. The use superglue to fix them properly to the wheels (although there's not much to be seen on that model... How is it, anyway? Where did you find reference on the beast(s)?
Posted by Rob Gronovius on Saturday, June 14, 2003 8:32 AM
Stapling will not work with this track. I tried to assemble the tracks with two different kits. Staples will work with this kit better than the kit-supplied pins. Someone suggested it since they built it in this manner.
Get a bunch of unused staples and break them into separate pieces. Flatten one leg of each staple so you have an "L" shaped pin. Use this instead of the kit pins.
I built the tracks in runs of about 10. Any more and the slightest handling would cause the track to break apart. There is an article in the Jerry Scutts Osprey Modelling Manual about accurizing this kit.
I've been conversing with someone in Austrailia who has a real one nearby.
Posted by Moses on Saturday, June 14, 2003 12:16 PM
Hey Rob, just realized you were Sabot on Armorama foums. Great site over there. Been registered since February 2002 under the calsign Tiger1.
Rob
Posted by Rob Gronovius on Saturday, June 14, 2003 9:21 PM
Rob
Hello then. I guess my last name is just so common that people think there are more than one of me! Smile [:)]
Posted by Anonymous on Monday, June 16, 2003 7:49 PM
Thanks-a-million to all...I'll try the CA first. If that doesn't work then I'll try using staples. There isn't a lot of info out there on the A7V, so some of the details have to be taken for granted that they are close to correct. I purchased mine through Squadron mail-order if anyone is interested. The kit falls far below the new standard of todays models but it is a welcome change from WWII Panzer-mania. Again, thank you all for the help.
M. Wilden
    January 2003
Posted by shermanfreak on Monday, June 16, 2003 8:29 PM
Here's a link to the only surviving A7V. Don't no if they will help or not.
http://www.kithobbyist.com/AMPSNewZealand/realafvs/A7V.htm
Posted by Anonymous on Wednesday, July 9, 2003 5:22 AM
Hey Man !!!
Super glu is the best for that. Put one or two drops, hold the two parts with wood pins and let them dry overnight. It works !!!
Good modeling
