HEY! Gimmee a break, I'm a nut for things with wings, not a track head!
![Wink [;)]](/FSM/CS/emoticons/icon_smile_wink.gif)
As far as the technique, it's all in who is applying said technique. I had very definite notions as to what I wanted to represent (alotta chipped and damaged zimmerit) and so the screwdriver was perfect for what I had in mind. Remember, just 'cuz it don't work for one doesn't mean that another cannot make it work!
Anyhoo, I patterned it partly after a Panther that I was able to crawl all over up in the Great White North. It was hatched on the lower hull sides, and the rear plate just had the stuff applied with no pattern whatsoever.
Not being one to trust museum pieces or restored vehicles, I called our armor guru (Bob Collignon) over to tell me if this was actually zimmerit on the back and, if so, if they often applied it that way. He seemed to think that it was possible, so that's how I did this Panther.
This example, typically, had no zimmerit up top. I did, however, choose to put some on my Panther, just for the hell of it. This thing was a testbed more than anything, and I wanted to try some things, especially zimmerit, before I proceeded on a "good" build.
Here's a couple shots of this example, you can't see the hatched stuff on the sides, it's in the areas of heavy shadow. But in the second shot you can see very clearly how it was applied to the rear plate.
I have a piece of zimmerit from that Panther on my workbench, and it's really weird, in a cool sorta way, to hold a miniscule piece of history in your hands...
Fade to Black...
