Tamiyas M60A2
Tamiyas M60A2
Posted by CTrill09 on Sunday, August 10, 2003 2:23 PM
i recently looked at some of my unbuilt kits and i found the motivation to build Tamiyas M60A2 as my net kit, as soon as i finish the M1A1 Abrams which is nearing completion. I will post pics of that as soon as possilbe for all you guys to evaluate and share. I opened the box and i think i want to do this one out of the box cause i dont feel like spending any addiional money on it. I looked at the spotlight and realized its open, and i was wonderin if any you guys new of anywhere i can go to look or possibly build to produce a clear parts cover to fit in the spotlight?? Anything else about the kit would be real appreciative if you guys know of anything else.
Photobucket
Posted by Spamicus on Sunday, August 10, 2003 2:40 PM
Try using a clear acetate document proctector. It's clear and easy to trim to fit. One of them will last you forever.
Steve
Posted by J-Hulk on Monday, August 11, 2003 12:42 AM
Doesn't that kit come with that clear part? I think it does. Make sure it's not stuck under a flap in the box somewhere or sandwiched between the instruction sheets. It's small and flat, and loves to hide!
~Brian
Posted by Anonymous on Monday, August 11, 2003 6:15 AM
MM makes a clear part maker , a glue made for attaching windows that dries completely clear. It's called window cement and it can also make small clear parts...check it out:)
    May 2003
Posted by styrene on Monday, August 11, 2003 7:03 AM
I've built a couple of the Tamiya M60s, and they're old kits. I don't ever remember seeing a clear part for the spotlight. The idea of clear acetate from a document protector is excellent. That is exactly what I used, and the results are pretty good.
Gip Winecoff
Posted by Rob Gronovius on Monday, August 11, 2003 2:06 PM
I used a clear piece of cellophane tape on mine many years ago. Still shines through.
