Wash to Weather a Tiger
Posted by Anonymous on Tuesday, August 12, 2003 1:06 AM
Hi Gang !
I'm very new to Modelling and I have question.
When using a wash to weather a model, what colour do you use ???
The base colour is Dark Yellow.
Thanks
Posted by djmodels1999 on Tuesday, August 12, 2003 2:19 AM
I'd use a darker shade of your base paint. In this case, you'd get great results with Burnt Sienna (that's the name of a paint in the artist's range of colours, and that can be found in oil-based, acrylic or in watercolour formulae. Persnnaly, I'd use the oil or the watercolour as they give you more flexibility than fast drying acrylics.
Posted by Moses on Tuesday, August 12, 2003 9:46 AM
I personally use Raw Umber on Dark Yellow base coats, with a little black at times on the lower sections. Raw Umber is more subdued then Burst Sienna. Burnt Sienna is more on the reddish yellow side. I use Burnt Sienna mixed with yellow for rust.
"ZIM FIRST, ASK QUESTIONS LATER!!"
Posted by Anonymous on Tuesday, August 12, 2003 10:22 AM
horry,
Raw Umber or Burnt Sienna are the colors of choice for nearly all color-camo schemes. I also use Black around the tracks and engine/exhausts. If it seems too light at first, you can always add more (remember, it's a wash not a paint)
Also, remember to cover the piece with a good gloss coat before the wash. This lets the color flow more evenly into seems and panel lines.
Good Luck!
Posted by djmodels1999 on Tuesday, August 12, 2003 1:21 PM
Contrary to what Erock is sying, I would not do the glossy paint step... You can improve the 'flow' of the paint, in the cae of acrylics and watercolour with a drop or two of dishwashing detergent and a couple of drops of white vinegar. With oils, turpentine will do, but DO make sure your base coat, if oil based (enamel) is well dried first!
