76 MM Short or Long
76 MM Short or Long
Posted by berny13 on Wednesday, August 13, 2003 10:19 AM
I have a question for you Sherman freaks. I just finished reading a book on 20 th century armor warfare. The Sherman tanks that had the 76 MM guns, used the short or long barrel cannons. The book stated than the same ammo was used by both, to cut down on supply problems. I, being schooled in mechanics and aeronautics, have come to this conclusion. Am I correct in my observation?
The short barrel cannon, should have a greater muzzle velocity. Reason being, a short barrel produces greater kinetic energy because the gas can expand only so much. If the gas charge reaches its max pressure, at say for instance four feet, any thing beyond that will result in friction slowing down the projectile. A short barrel cannon would then have more penetrating power, at short range. It would not have very long range capability.
The long barrel cannon, Has greater range due to the projectile being more stable. A longer barrel would also result in less muzzle velocity due to less kinetic energy. Result, less penetrating power at any range. The longer a projectile has to travel, the more gravity and friction come into play.
So what is the advantage of having a long barrel over the short barrel, other than range?
Berny
 Phormer Phantom Phixer
On the bench
Posted by J-Hulk on Wednesday, August 13, 2003 10:24 AM
Accuracy?
Also, maybe the longer barrel allows the pressure on the projectile to increase more than it would with a shorter barrel.
The same reason you can spit a spitball farther through a straw than just out of your mouth.
Ptooey! Higher velocity!
~Brian
Posted by berny13 on Wednesday, August 13, 2003 11:34 AM
I don't see how. Once the gas reaches its max pressure, it will still push the projectile out of the barrel, but I will not increase its velocity. A projectile going through a barrel reaches its max velocity inside the barrel, after the gas pressure reaches its max pressure. The longer a barrel, the less pressure at the end of the barrel where the projectile exits. Anything after that is for stabilization. The more stable a projectile, the less the wobble and tumbling, resulting in more range and accuracy.
True. But here you are talking about volume. There is less volume in a straw, more pressure and stability. Using just your mouth you have more volume, less pressure and stability.
Berny
On the bench
Posted by J-Hulk on Wednesday, August 13, 2003 12:43 PM
Maybe a bad analogy.
Truth is, I have no idea!
But in practice it seems that the longer barreled guns are the higher velocity weapons.
Any other theories as to why? Is it simply the longer barrel that somehow increases velocity, or is the shell itself beefed up to chuck a projectile more forcefully out of a longer tube at higher velocity in order to take advantage of the better range and accuracy? I'm thinking of the Tiger I and Tiger II 88mm cannons and ammunition here.
~Brian
    May 2003
Posted by erush on Wednesday, August 13, 2003 1:12 PM
Both of you are right on the basics.
A projectile fired by a powder charge is propelled by the gas from the burning powder. The maximum pressure of that volume of gas will develope at a certain point in a long enough barrel and after that the projectile does indeed begin to slow down due to friction.
Now, all calibers and powder charges have a different barrel length where that maximum pressure is reached. This can only be truely found by testing and will change with different powder charges and projectile weights. This will give you the maximum muzzle velocity for a round.
Then effective range of a projectile is determined by the mass of the projectile and the velocity that it leaves the barrel. The heavier and faster it is, the more enrgy it will carry downrange.
That's the basics, you also have to get into chamber pressures and coeificient of friction on the projectiles and that's why you see so much about handloading amongst firearms enthusiests.
As for the length of the barrel effecting accuracy, it does only to a point. Once the bullet reaches the maximum spin rate (in a rifled barrel) beyond that accuracy is effected more by the barrel itself in how much flex and vibration occures while the projectile travels down it. (Heavy barrel rifles ((thicker walled)) are generally more accurate). Also a thin walled barrel with warp more from the heat if fired too fast.
As for smoothbore cannons accuracy again is determined by the barrel vibration etc. but also the projectile itself being a stable design that maintains the stability after it leaves the bore or in modern cases, finned projectiles that maintain the stability.
* deep breath * Tongue [:P]
hope that down and dirty helps some.
Eric
Hi, I'm Eric and I'm a Modelholic too. I think I have PE poisioning.     "Friendly fire...isn't"
    May 2003
Posted by erush on Wednesday, August 13, 2003 1:24 PM
BTW, The to answer the length of the Tiger 88 barrel lengths. Yes it was due to the round requiring a longer barrel to maximize the potential of velocity for the round. Basically the bigger the diameter and bigger the powder charge the longer barrel you'll need up to a point. It's a weird science and still usually takes test fireing to get the best results. you can get close on paper with most ballistics but only close.
Also on the Sherman the short barrel cannon probably did not have the velocity or the accuracy of the long barrel version. I think that barrel was too short to be worth anything, but that's just my opinion. I've not seen any ballistic data for either one.
Eric
Posted by berny13 on Thursday, August 14, 2003 8:13 PM
erush. I can fully understand what you are saying. The book states that both tanks used the same ammo. In my way ot thinking that would give the long barrel a disadvantage. Ammo wasn't specfically developed for the long barrel until early '45.
The book shows that the long barrel version would fire so the round would arc up and fall down on the top of an enemy tank, instead of shooting directly at the side or front. I don't know if this was because of the thicker armor of the German tanks or to compensate for the lack of penetrating power of the 76 MM cannon.
Berny
On the bench
    May 2003
Posted by erush on Thursday, August 14, 2003 8:33 PM
I can see that Berny. If the round was designed specifically for the short barrel cannon then the longer barrel could actually shoot the round slower. This would require a greater arc to the ballistics of the projectile to shoot the same distance at a slower speed.
Eric
