Lacquer Paints...
Lacquer Paints...
Posted by Anonymous on Friday, August 22, 2003 10:18 PM
Hi all.
I have heard mention in FSM, and on the site about lacquer paints/sealers. The only use I have heard for these here in NZ is in the automotive spray industry. So im not sure if its an "Americanism" , or my education is lacking![:0]
I wanted to give pastel weathering a go on my Su 122, but have no lacquer to apply as an adhesion base.
What other options do I have with no lacquer to hand?? I have acetone, can I just use a Matt varnish for adhesion of the dust?
Oh, I have been playing with nugget & a hairdryer, initial results are promising!!
Thanks,
Ian
    January 2003
Posted by shermanfreak on Friday, August 22, 2003 10:33 PM
What I do with pastels Ian, is use them as my last weathering technique on all my models. I grind the pastels up to a fine dust and apply by scrubbing it into the nooks and crannies and / or applting a dusting with a fan brush. Once this is complete, so is the model, I never seal the pastels onto the model. I found that sealing them in takes away from the final effect too much.
Posted by Anonymous on Friday, August 22, 2003 10:47 PM
The mention of lacquer you have been reading about most probably refers to Tester's Dullcoat Lacquer, a common clear-coat flat lacquer used to seal paint jobs and leave a dull finish. While it is true that car modelers sometimes use automotive lacquer paint because of its high luster and ablility to be polished, If you are a tread-head, there is no reason to mess with these highly flammable and highly toxic paints. Metalizing paints, used to simulate natural metal finishes on aircraft, are also commonly lacquers. If you can't find Dullcoat in NZ, any matt vanish varnish will do, providing it can be properly thinned and sprayed without any problems.
