Aber or Eduard
Aber or Eduard
Posted by Anonymous on Monday, October 20, 2003 7:33 AM
I just got my Sturmtiger from ebay!!Big Smile [:D]
And now have to decide on detailing, so Aber or Eduard? i have only had a go at PE once before and that was Aber for Panther g.
I can get Eduard cheaper but does that mean its not as good?
Oh and lastly. The Sturm has separte track links [:0] i've not had that before. anyone got some advice? it looks hard to me.
    May 2003
Posted by erush on Monday, October 20, 2003 7:42 AM
Aber is going to give you a lot more on a p/e set and that's usually the difference in the cost. However, Eduard usually has the main items you need to add and less of the tiny stuff. So just decide how much you want to do on it.
On the indy tracks, I haven't built any yet but I hear the main thing is to line them up against a straight edge whe you glue them to keep them straight. Good luck on it box1.
Eric
Hi, I'm Eric and I'm a Modelholic too. I think I have PE poisioning.     "Friendly fire...isn't"
Posted by Moses on Monday, October 20, 2003 9:04 AM
Hey Box, I persoanlly feel Aber frets are of much higher quality. Don't get me wrong Eduard is great, and I use them often, but the detail you can achieve with Aber is fantastic. The only problem with Aber is they are known to split there frets into seperate packages, unlike Eduard, who include everything you need in one.
As for the individual tracks, I stay far away from them, and opt to use ModelKasten workables or Fruilmodel Tracks.
Good luck Box, the Sturm is a great kit.
Cheers
Rob
"ZIM FIRST, ASK QUESTIONS LATER!!"
Posted by J-Hulk on Monday, October 20, 2003 10:44 AM
Eduard is more pragmatic, simply put. Easier to use, less frustration, with good choices of what to etch, in my opinion.
Aber etches almost everything, a lot of which, in my opinion, is wholly unnecessary. Way over the top. And what they choose to etch (again, almost everything!) is overly complicated, and very difficult to assemble. The frustration factor is very, very high with Aber.
But, if you can get it together cleanly, the Aber PE is fantastic. In fact, even after giving the above opinion, Aber is what I usually buy.
The reason is I can choose what I think will benefit from being replaced by an etched part. If I think the kit part is fine (if it even exists!), then I have no problem not using the Aber part. You can build a pretty good PE spares box that way!
As for individual trax, aftermarket sets like Friul or Modelkasten are good options, but you can certainly get good results from some kit trax, too. I'm not familiar with the kit you have, but I've done several Dragon kits, and have had no problems getting good results from their link trax. You just have to deal with sink holes and other clean-up problems.
The key to any of them is just doing them, I reckon!
Good luck with whichever path you choose.
~Brian
Posted by Anonymous on Monday, October 20, 2003 11:26 AM
I echo what J-hulk said, I have used both and the aber is better if you can decide what you want on the model, but you really can't go wrong with either, so if money is an issure, then use Eduard and you will do fine. I have never used single links, I will on my next model.
    January 2003
Posted by wipw on Monday, October 20, 2003 1:35 PM
My 2 cents worth...
I wholly agree with everything that's been said. Aber does some fantastic work, but after it's on the model, often, I'm not sure the result is worth the frustration level. For example, an equipment clamp in an Eduard set is made up of two parts. Those in Aber, three. Not much difference in two parts vrs. three. You won't say that once you've done an Aber clamp! I worked for over a half hour last night trying to get one Aber clamp put together. After tweezerpulting 3 of the 4 parts I'd cut off the fret, I gave up for the night. (I did manage to find 2 of the 3 parts!!) But their parts are beautiful.
Also, I feel that Eduard's instructions are usually much more comprenhensive and the illustrations clearer than Aber. Expect with Aber to put a lot of time into pouring over research to find out what an item is and where it went.
My recommendation would be to get a few more PE sets under your belt before going with an Aber set.
Good luck with whichever way you go,
Bill
Bill ========================================================== DML M4A2 Red Army ========================================================== ========================================================== -- There is a fine line between "hobby" and "mental illness". (Author unknown)
Posted by tigerman on Monday, October 20, 2003 5:29 PM
Hi Box, I personally think indy tracks aren't that difficult. I too, was scared to try them. Now I almost feel guilty doing vinyl, which are less accurate. On a tank that needs some sag, indy tracks are the way to go. I have not yet built Modelkasten or Friul sets. Just do the tracks in sections. I usually build one set that wraps around the drive sprocket and another that wraps around the idler. Finally, link them up with a long stretch of track on the top and bottom. Use slower setting glue to ease construction. Try it, you'll be glad you did.
"It is well that war is so terrible, lest we grow too fond of it."-R.E.Lee
 Eric
Posted by mark956 on Monday, October 20, 2003 6:33 PM
I agree with Bill. Eduards instructions are easier to understand compared Aber. I will be using a Aber pe set for my M4A3 Calliope build for the first time. I will leave feedback on how it goes.
Mark956
