help on stug iv tracks
Posted by Anonymous on Wednesday, February 19, 2003 12:18 PM
I read somewhere that to make tank tracks appear "loose" you put them in hot water. I did exactly this on the tracks that came from academy's stug iv kit and they shrunk and there is no way to connect them together. Is there any to correct this problem since i do not feel like going out and buying new tracks?
    January 2003
Posted by shermanfreak on Wednesday, February 19, 2003 9:16 PM
Placing tracks in warm water usually makes them more pliable. I've never heard of them shrinking...as far as correcting this problem I'm afraid you might be in the market for aftermarket tracks.
Posted by Anonymous on Wednesday, February 26, 2003 8:25 PM
Once you put the tracks in the water, let them sit for a little bit, then carefully stretch them. You do need to be careful as not to pull them apart. It will take a couple, maybe even more trys doing this, but it does work. OR like Shermanfreak said, you'd probably be better off now getting after market tracks.
they can be easily made to look loose as they are individual links. Some are even metal and the weight themselves give the saggy look you need for your tracks. They really are worth the money. HTH'd Chris.
