QUOTE: Originally posted by bob3242
MANY THANKS. I was given a PzKw IV from Italieri that I've started. I'll try weathering on it. Again, THANKS! Bob
Good kit to work on, Bob. For it's age it offers some good detail; For my money it has the best-detailed single piece tracks on the market. Also those separate fenders (which is something I would like to see more armor manufacturers do... are you listening, Tamiya??) make modeling dents, missing fenders and other battle damage a breeze.
A couple of weathering tips, if I may be so bold: Be sure to give your model at least two light coats of a flat laquer before starting to weather, especially if you plan to use mineral spirits or turpentine for washes. This will seal the paint and your washes will flow smoothly across the surface. I suggest Flo-Quil Figure Flat, which is more expensive than Testor's Clear Flat but gives a better finish.
Also, while Italeri uses very thin decal films, some manufacturers (Tamiya, again) use much thicker films which weathering will accentuate unless you cut very close to the marking, which is nearly impossible for most of Gemany's division and tactical markings. I would suggest making the purchase of dry-transfer markings, available from VLS and several other manufacturers. They're inexpensive and save a lot of headaches. And while they're impervious to laquer, I have had one or two lift off when assaulted by turpentine washes. I have no explanation as to why. So, after placing the dry-transfers I am sure to shoot a little clear flat over them. Hope this helps. Also, if you're serious about doing more armor, I would suggest you get Shepard Paine's "Modeling Tanks and Military Vehicles." It's a little dated on some of it's info but the chapters about basic construction, weathering, and adding detail are timeless and he offers great advice for beginning track-heads.Good luck and have fun!
Ne cede malis (Latin: Yield not to misfortune)
