1/35 US Army duffle bags
    May 2003
Posted by qmiester on Monday, November 10, 2003 9:02 AM
I'm currently working on an M109A6 Paladin for a friend. When completed, it will be displayed as if it were on a firing point at AT. Does anyone out there know where I can find a 1/2 dozen 1/35 scale US Army duffle bags? Going to mount them in the bustle baskets.
Quincy
    May 2003
Posted by erush on Monday, November 10, 2003 10:21 AM
Verlinden has a set out now with modern bags and packs in it, and Tamiya has done a plastic set for the M2 or M113 (It could be used with anything modern) that has duffels bags, sleeping bags, alice packs etc. Or if all you want is duffels, you could mold some of your own out of putty.
Eric
Hi, I'm Eric and I'm a Modelholic too. I think I have PE poisioning.     "Friendly fire...isn't"
Posted by Anonymous on Monday, November 10, 2003 10:46 AM
IS your friend in the guard or reserves?
I know most of use either try to keep our bags inside the bussel rack or if we have to put them outside, we place them inside a tarp and use ratchet straps to secure them down. but most of this is usually up to the command for our guns and they really don't care it seems so we keep them dry and inside.
Hope some of this helps?
I've placed a lot of ref pics on ron georges site if you need ref material.
    July 2003
Posted by animal on Monday, November 10, 2003 10:54 AM
I can cast some of the bags for you if you want.
Animal wants trucks!!! http://community.webshots.com/user/gtadw
Posted by Anonymous on Monday, November 10, 2003 11:18 AM
I just thought of a good one, it might work ?
get some JB weld and make the bags from it, if you don't like the shape just file it to a shape you do like?
    May 2003
Posted by qmiester on Monday, November 10, 2003 6:53 PM
Redleg1-7FA - He's Kansas Guard - now Ops Sgt for 1-127FA - I retired out of there last Nov (Not as the ops sgt - ain't that crazy - was the local nbc puke) - Now I only go to Riley when I want to (PX ya know - not to the field)
animal - Thanks - may take you up on that
q
Quincy
    May 2003
Posted by Build22 on Monday, November 10, 2003 6:58 PM
Try this place for duffles etc
http://discountmodels.com/bags.htm
Good Luck
Jim [IMG]
Posted by Anonymous on Tuesday, November 11, 2003 1:13 AM
We had some Kansas guardsmen in our community last year, you might not have made the trip as I noticed they were here when I got back from Kosovo in Nov.
    November 2003
Posted by gunner19k on Thursday, November 20, 2003 5:27 PM
Another cheap way to do duffle bags is to use the printed foil from cigarette packs... I cut the pull off piece to size, wrap it around an exacto knife handle, fold and glue the bottom and sides, add strips for the shoulder straps, fill it with sculpey or whatever to form and weight it, and then paint it; The good thing about cigarette foil is that it is usually embossed in a kinda fabric pattern, which is great for drybrushing over the base color...
Also, forming them individually this way eliminates the "cookie cutter", identically molded look you will find from AM stuff...
"I won't be wronged. I won't be insulted. I won't be laid a hand on. I don't do these things to other people, and I require the same of them" - John Wayne as "The Shootist" WIP's- Revell 1/32 P-47D Thunderbolt Tamiya 1/48 A6M5 Zero Academy 1/48 P-47D Thunderbolt Airfix 1/24 Ju-87 Stuka
