question for shermanfreak
Posted by Anonymous on Tuesday, November 11, 2003 12:12 PM
i tried making camo netting out of cheesecloth and a mixture of white glue, water and paint and they do come out nicely , my question is at what point do you add it to your models and how do you do it exactly do you "paint" your cheesecloth? on the side then add it to your model while its still wet or do you paint it with it on the model before you do the weathering? the thing is i want to add some to my 251/1 but i just finished all the weathering on it and now i'm afraid it will put some of the glue/paint mixture on it kinda ruining it
now a spinoff question , when adding tree branches to a model how is it attached to the veicule? the ones stuck into netting is obvious but its the ones that are just on the veicule are making me scratch my head , how did they do it historicaly , did they have some kind of glue to put it on or where they tied down with rope and whatnot
    January 2003
Posted by shermanfreak on Tuesday, November 11, 2003 1:16 PM
Hey Max .....
Here's what I do, though others may differ in their methods a bit. First A/B the cheesecloth in the desired colour. Lay it on the model in the approximate location that you wnat to locate it in. Using a brush to apply your mixture of white glue / water, liberally apply it to the cheese cloth until it is fairly good and wet locating it at the same time exactly where you want it. Allow it to dry, usually overnight. Dry brush the net for highlights. If you have a little "overflow" of the glue / water mixture, don't worry too much about it, it can be covered easily with normal weathering techniques. Complete the weathering with the rest of your kit.
As far as branches and stuff go, I've seen pics of them tied on with rope, stuck into nooks and crannies, crammed behind wire mesh, and in some cases even seen where the crew welded pieces (approx 6") of small guage pipe to hold the branches in place.
Posted by Anonymous on Tuesday, November 11, 2003 1:51 PM
'Bout time you answered that one Robert, I've been waiting here all day!Wink [;)] Sounds like a great way to do the netting!
Ron.
Posted by Anonymous on Tuesday, November 11, 2003 2:07 PM
alright , i'll try that , i'm trying to get this 251/1 done, hopefully by the end of the day it will be finished. i'm sick of looking at it unfinished and want to move on to something else (probably a pak40 to put behind the 251 just to keep me busy until dec1 then its my panther)
Posted by mark956 on Tuesday, November 11, 2003 3:59 PM
Thanks for the info on the netting, it will come in handy. PantherLehr are we going to see pictures of your model.
mark956
