44 year old Entex 1/16 scale Mercer Raceabout kit found, suggestions sought ?
Posted by Don Stauffer on Friday, January 25, 2019 9:13 AM
oldermodelguy
I think the real challenge is going to be the black striping, especially on the fenders. Meanwhile I have the rear deck piece shown in the post above yours to repair. And quite a lot of bits of flash to trim off through out the kit.....
For that kind of work I like to use homemade inkjet decals.  Black lines to use over a light color are the easiest kind of decals to make.  You do need a drawing program for your computer.  For those kind of markings the one that comes with Windows would be fine. If you have an Apple I am not sure what is available.
    November 2018
Posted by oldermodelguy on Friday, January 25, 2019 9:45 AM
Don Stauffer
oldermodelguy
I was considering drafting pens and straight edge and compass, caligraphy pens won't work because the tip  flexes when against an edge varying the line. But we used to do fine lines in drafting school back in the day ( many moons ago now). Today they have the technical pens. I thought of decals too, but wasn't sure of the programs. Thanks Don !
    September 2012
Posted by GMorrison on Friday, January 25, 2019 9:59 AM
You can try a version of both. Without a lot of research it would appear that you'll needs a lot of straight lines and a series of ends on fenders. A couple of circles on the ends of the gas tank.
Those "lines" are a thin one next to a thick one.
I'm surprised there were no decals for this in the kit; it's a big part of the look.
So, you could draw these with an ink pen on paper at a much larger scale, and then reduce them to the right size for the model. This will clean up the lines considerably. That would be the art to print on clear decal film.
    November 2018
Posted by oldermodelguy on Friday, January 25, 2019 10:24 AM
GMorrison
I dug around in the box believe me, but even thinking back the 44 years I recall the lines were to be the issue, not so much the thick line but the pin stripe is fine. The fenders are embossed though, so is the rear deck. I've seen some real samples that have the striping on the frame rails, that probably isn't happening. I saw one with a single tear drop stripe on each spoke, I can handle that with a fine brush or calligraphy pen, done that before.
In the past I cut my own stencils for both models and 1/1 ( did my share of 7 up logos on beverage trucks back in the day). Might be a pitb for this one maybe, but maybe not. You need a good sharp blade and low stick masking tape, good pens straight edges etc.. But once it's all masked off two light coats of paint and it's done. We shall see. My mind isn't on that yet.
Posted by Don Stauffer on Saturday, January 26, 2019 6:47 AM
As an experiment, you could try using a sharp pen on the inkjet decal paper.  It may be easier to draw on a flat sheet.  You'd still need to seal it like you seal inkjet decals- glosscoat or something.
    November 2018
Posted by oldermodelguy on Saturday, January 26, 2019 9:47 AM
Thank you Don for that.
On the bottom side of the running board I found Bandai Made in Japan.
Meanwhile here is the back plate I glued in to hopefully help support the break in that rear deck piece. It's setting up now, then I will saturate the plate with ca glue. Probably have to use a bit of putty on the other side. There is a second break to deal with as well but wider material.
plate
    November 2018
Posted by oldermodelguy on Tuesday, January 29, 2019 10:23 AM
In the paint booth, first round of primer on the rear deck:
Ptimed deck
By the way this is my home made updraft spray booth ( the photo is shot crooked, the booth isn't perfect but it isn't that bad either lol:
spray booth  This my home made updraft booth, the photo was shot crooked, it isn't quite this warped lol.
    July 2019
Posted by Bruce E on Monday, July 29, 2019 6:07 AM
Hello, oldermodelguy and everyone -
I, too, am an older model guy (age 59), and I just stumbled across this community while searching for Mercer Raceabout images. (I had just come across Jay Leno's video of his own Mercer and was inspired, since this was a favorite car of mine since I was a little kid.)
Which gets to my main point: I, too, have an unbuilt 40+ year old Entex Raceabout model (!). Reading this thread is making me think that it might be time to dig it out and see if I can finally complete it. I'll save the story of why it's been in storage all these years for a separate post where I'll introduce myself.
I did have a question, though, oldermodelguy - you mentioned the yellow, black, gray, and brass parts, but I seem to recall brown parts with swirled colors that were meant for the wooden parts of the car (floor and dashboard) - does yours have those?
I can also confirm that there were no decals in this model. I, too, was stumped by the challenge of doing the pin striping on the fenders and wheels.
I'll post some pictures once I've dug mine out, and I'd also welcome any tips you have from your experience.
- Bruce
    July 2019
Posted by Bruce E on Monday, July 29, 2019 8:42 PM
Augh!! After posting my previous comment, I went to dig up my old model and made several discoveries that came as almost complete surprises:
1. It turns out I did complete the model, or very nearly did, all those years ago. I'd completely forgotten.
2. It appears that the model suffered some kind of terrible accident, perhaps during a move at some point (?). It is now in many pieces, several having snapped in two. I don't remember how or when this happened; all I have is a vague memory of a feeling of total despair that compelled me to pack the model away until the day when I could bear to look at it again. Maybe that day is finally coming? (see photo link below)
3. I never painted it! The yellow parts are all unpainted; evidently I thought the color of the plastic was close enough to the right yellow that I could leave it. I'm not sure why I would have thought that. By the time I worked on this model I would have had plenty of experience painting other models. Several of the small parts are in fact painted such as the dashboard instruments, but the main body panels are not.
4. There is some black paint on some parts, but the only pinstriping is actually thin black tape of the type used for graphic design. If I can bear to attempt to restore this model, I'll definitely have to come up with a way to do the pinstripes for real.
5. There are five or six parts that I recognize as "extra" parts that did not appear in the instructions and whose purpose I could never determine. I'd be very curious to hear if oldermodelguy has the same parts, or if his instructions are different from mine and actually identify them.
I'm going to have to assess this situation for a while before I do anything. It's been a good 30 - 40 years since the last time I set eyes on this model, so I guess I can take a little longer before deciding on the first steps toward restoring it.
    June 2014
Posted by Tanker - Builder on Tuesday, July 30, 2019 7:56 AM
Pawel;
   Would you be so kind to message me. I have a stupid question I need to ask. Books haven't been any help. Please?  Tanker-Builder
