Do you guys scratch build them or is there a place you can buy wheelie bars maybe in resin or etched brass or stainless? Not being a drag racer myself where do they attach to the undercarriage?
While I'm asking, would pro street need a roll bar, roll cage? I was thinking a simple roll bar with supports back to the rear floor pan where the back seat is or used to be.
I may as well be a complete pest. Is there some trick to opening a trunk? I can probably cut one open using an X-Acto knife but if anyone has an old Indian trick please share. What about hinges?
Do you use a base coat under pearl paint? I painted a Chevy Nova primed gray with Boyd's Pearl Yellow and it came out slime green. I repainted it white then yellow again and it is more yellow. I did the same with a 51 Chevy primed gray then sprayed with Boyd's Roadster Orange. It came out more copper color than orange but I kind of like it so that's the color it will stay.
