Flat Tires?
    January 2009
Flat Tires?
Posted by Mumpster on Monday, March 16, 2009 9:32 PM
Does anyone know how to model a good flat tire.  I was thinking about just cutting the bottoms but i don't think that would look good.  Any suggestions?
    June 2008
Posted by lewbud on Monday, March 16, 2009 11:08 PM
You might try grinding on the inside of the sidewalls til they wouldn't support the weight of the model, or you might try to see if there are some resin flats around.  Don't know of any off the top of my head though.
Buddy- Those who say there are no stupid questions have never worked in customer service.
    February 2008
Posted by SkullGundam on Wednesday, May 20, 2009 10:47 PM
This is my first time looking around on the autos forum so someone may want to comment on this suggestion.  Could you heat the tires up till the bottom kind of melts flat under the weight of the car?
If at first you do succeed, try to hide your astonishment.
Join the Club and Swap Books for Free! - PaperBackSwap.com
    April 2008
Posted by smeagol the vile on Thursday, May 21, 2009 2:39 AM
I dunno if this would work, dont do autos much, but you could cut the back inside (facing the center of the car, away from the outside).  Cut that out in a square, put superglue on the inside of it and press it against a hard surface while on the wheel, that would be my guess if you had some scrap tires to try it on
Posted by ajlafleche on Thursday, May 21, 2009 4:20 PM
You will also have to work with the suspension to partly increase the weight on that shock while adjuisting the other shocks accordingly. Simply flattening one tire will leave that tire floating or its opposite off the ground.
    November 2008
Posted by deadhead on Thursday, May 21, 2009 6:23 PM
I recall a tip in FSM or the sister pub Scale Auto a while back about an iron bought at a yard sale used to make the tire flat on one side. With practice you should be able to get a bulge too.
Good point about the suspension Al, unless this is for a dio then adjust the ground.
    January 2008
Posted by acmodeler01 on Friday, May 22, 2009 11:09 AM
I've flattened the hard vinyl tires before with a lot of success. I sanded, carved, or otherwise removed a section of the tire (tread and sidewall) enough that it looked mostly flat, then melted it with a candle and pushed it onto a flat surface. the result can be seen on my 1969 Charger in the link below my signature.
Al's got a good point about the suspension needing to be adjusted, it does take a little tweaking to get it to sit right.
    February 2008
Posted by SkullGundam on Friday, May 22, 2009 6:23 PM
Those look really good.
