Possible source for braided hose.
    July 2009
Posted by Back to the bench on Saturday, September 12, 2009 9:43 AM
I was replacing some speakers in my truck the other day and noticed that the braided wire that is used to connect the terminals to the voicecoil looked a lot like braided hose. I did a little research and found that the wire is called tinsel wire and consists of tinned, braided copper with a core (polyester I think). Here is one place I found that carries it...
http://www.speakerrepair.com/mm5/merchant.mvc?Screen=PROD&Product_Code=Leadwire&Category_Code=AIII-SP
 There are other diameters made but I have not found distributors, only a ton of off shore manufacturers when I Google tinsel wire. I also came across some wire used in fly tying that looks like it may be useful as well...
http://www.basspro.com/webapp/wcs/stores/servlet/Product_10151_-1_10001_61015____SearchResults
 May be old news to most, but new to me.
Gil
    August 2009
Posted by DuHast on Saturday, September 12, 2009 12:14 PM
Another thing you could use is that fine braided steel wire that you can get a lowes or home depot.
http://locksknobsandhinges.com/Stainless_products.html
    September 2009
Posted by Martin_G on Sunday, September 20, 2009 1:43 AM
You might try DETAIL MASTERS for braided stuff. While they are mostly into 1/24 or 1/25 accessories I have bought braided stuff from them to use on 1/6 Tamiya Harley kits as brake lines & throttle cables. I'm very pleased with how it looks.
They had bigger stuff then what I used too!
HTH,
Martin
    January 2006
Posted by SprueOne on Sunday, September 20, 2009 11:03 AM
Those are some good sources and links up there. Thanks
I cut open an old XM radio antenna cable and found this:
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
