Cutting the body
    July 2003
Cutting the body
Posted by lizardqing on Tuesday, December 23, 2003 9:30 PM
I have never attemted this but what would be the best way to cut sections of the body off? I am going to need to remove the sides of a curved hood if that helps any more. Thanks.
Posted by maddafinga on Friday, December 26, 2003 11:04 AM
Razor saw if you can, otherwise, try using the back side of the point of an #11 and just keep going over it until it cuts through.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
    July 2003
Posted by lizardqing on Friday, December 26, 2003 10:35 PM
Thanks Madda. Hopefulyy I don't mess it up first time out since I don't have a donor to try it out on.
Posted by maddafinga on Saturday, December 27, 2003 11:39 AM
I just cut out the door on my 1\72 spitfire. If you're careful and paitient, you can do it with a blade pretty easily. The fuselage was too small for my razor saw to get into, so the knife was my only option. Remember to allow for the width of the blade in your cutting. If you don't cut out quite enough you can always go back and trim a bit more, it's much easier than adding plastic that you accidentally cut away.
    July 2003
Posted by lizardqing on Saturday, December 27, 2003 1:52 PM
True, but seeing ow this is going to represent a shade tree modification on the race car, I don't think it has to be perfect, the one in the picture looks rather rough.
