#29 ESGR Coast Guard Busch Series Winner 2004
    July 2009
Posted by Mach2 on Sunday, December 27, 2009 11:35 AM
Really pleased with the color match and the way the decals came out.  I made decal templates from manila folder material, used the templates to trace onto the white painted body the outline of the hood and both side front & rear decals.  Then layed the templates over a strip of masking tape, traced the outline on the tape and then cut the masking tape on the traced lines.  Then I matched the hood cut masking tape template to the traced line and layed it down.  Same procedure for the sides.  Masked the body off and shot it.
Duplicolor auto white primer, Tamiya ts-26 pure white lacquer and Boyd's Sunburst enamel.  Added the post race details around the wheel wells and nose as well as a few Slixx goodies sheet tire rub decals to match the left side pic of the car on track.  Next up is the same scheme, but the #29 B Labonte ESGR Army that ran at the Texas Spring Busch race.
B Labonte won the final Busch Series race at Homestead with this car.
Mick
    May 2009
Posted by Brizio on Sunday, December 27, 2009 1:47 PM
Looks a nice clean work!
    March 2006
Posted by TD4438 on Monday, December 28, 2009 1:50 AM
Are those all separate decals?The car looks awesome.
    July 2009
Posted by Mach2 on Monday, December 28, 2009 9:36 AM
Thanks.
Yes, separate decals.  Here's the sheet;
and the car after masking and painting the orange with only the roof decal applied;
Mick
    May 2007
Posted by cuchulainn on Monday, December 28, 2009 4:17 PM
That is gorgeous!!! How do you do the tire lettering? I can't get mine to look that clean!!!
Southern Maine Scale Modelers/IPMS
    July 2009
Posted by Mach2 on Monday, December 28, 2009 4:47 PM
First thing is wipe the outside, the side with the raised lettering, with lacquer thinner.  Then sand the part of the tire that hits the ground for realistic effect.  On the 2006-07 kit wheels there are two raised ridges on the wheel, I take snips and cut the narrow raised ridge to help the hollow tire fit the wheel better.  install the tires to the wheels.  I take the Goodyear #1 and Eagle decals and apply them to the tire along with the  decals, apply the Aero wheel decals to the wheels.  Now take a silver, or white, lead pencil and dip the lead into water, shake off the excess water and rub the side of the lead lightly, LIGHTLY, on the raised "Radial" lettering and the "tire size" lettering, as well as highlight the raised oval and numbers.  Let these items dry and then I take a red, green or blue DecoColor  by Marvy/Uchida paint marker and make the dots and swipe a line thru the oval and raised numbers.  The last thing is put a dime on each wheel and spray the exposed tire with Testors #1260 flat clear lacquer.  Also, I use Solvaset on the Aero, Goodyear #1, Eagle and LR-1 RR-1, LF-1 & RF-1 decals prior to spraying the tire with the flat clear.  This helps melt the decal into the tire prior to flat clearing them.
Mick
