does anyone have an idea on how to get testers lacquer paint off after its been put on really bad had oil on my fingersfrom a bike and looked at the body to see what i wanted to do. Any help would be great thanks.
i use dot 3 brake fluid, cheapest one you can find, works super fast. and can be reused many times! lol
JTRACING i use dot 3 brake fluid, cheapest one you can find, works super fast. and can be reused many times! lol
I second the DOT 3 brake fluid. I just used it to removed Testors lacquer off of a R/M 69 Camaro body. Let is soak for about 12 hours and use a toothbrush to help remove the paint from the panel lines and molded details.
Good luck
Kevin
X3!!! Go with the brake fluid! :)
it funny I am doing it on the revell 69 camero
