Fish Tank Model
Fish Tank Model
Posted by Anonymous on Saturday, January 10, 2004 4:19 PM
Here's one for you long timers: I built a '48 1/2 ton Ford, submersed it in my 30gallon fish tank, and after about 4-5 weeks, parts just started to float to the top. It was gradually "coming unglued". Wa'd I do wrong?Question [?]
    January 2003
  • From: Upper left side of the lower Penninsula of Mich
Posted by dkmacin on Saturday, January 10, 2004 5:40 PM
What glue did you use?
Don
I know it's only rock and roll, but I like it.
Posted by Anonymous on Saturday, January 10, 2004 10:29 PM
Sorry about not mentioning the type of glue used....It was Testors Liquid Cement for styrene plastic (red container).
    November 2003
Posted by chopperfan on Tuesday, January 13, 2004 8:19 AM
I have a question.
I haven't built a model car in 20 years.
Why on earth would you put your pickup in an aquarium????
Randie Cowboy [C):-)]
Randie [C):-)]Agape Models Without them? The men on the ground would have to work a lot harder. You can help. Please keep 'em flying! http://www.airtanker.com/
Posted by Anonymous on Tuesday, January 13, 2004 3:36 PM
Hi there Chopperfan.....
Well, to tell you the truth, I wanted to set up an aquarium somewhat different than usual, and I wanted an automotive theme.
It (the Truck) looked pretty neat while it lasted. As it fell apart, it took on the appearance of a truck in the junkyard Big Smile [:D]
Maybe I'll try superglue next time????
Posted by cassibill on Tuesday, January 13, 2004 3:51 PM
Whatever glue you use would probably kill fish.
cdw My life flashes before my eyes and it mostly my life flashing before my eyes!!!Big Smile The 1/144 scale census and message board: http://144scalelist.freewebpage.org/index.html
Posted by Anonymous on Tuesday, January 13, 2004 3:54 PM
Good point Cassibill.
All 10 goldfish did in fact die, I think over the same period of time it took for the truck to come unglued.
Maybe I bettewr just forget it???Dead [xx(]
Posted by cassibill on Tuesday, January 13, 2004 4:39 PM
If you want a car in a fish tank find a ceramic one and clear glaze it. I have some odd stuff in fish tanks that way, like movie theaters, windmills...
    June 2003
Posted by M1abramsRules on Tuesday, January 13, 2004 4:46 PM
I highly doubt if white glue is toxic......Wink [;)]
    January 2003
Posted by stinger on Tuesday, January 13, 2004 7:27 PM
But isn't it also water soluble?
May an Angel be your wingman, and the Sun be always at your six
Posted by Anonymous on Tuesday, January 13, 2004 7:31 PM
But isn't it also water soluible?
Yup, White glue would reduce the junking time from 4~5 weeks to 4~5 minutes.
Big Smile [:D]
And I guess it might still clock up the gills of the poor fishes.
Posted by cassibill on Wednesday, January 14, 2004 7:54 AM
the paint would be another problem
Posted by Anonymous on Wednesday, January 14, 2004 10:49 AM
You may have used too much glue, which would leech out into the water, poisoning the fish, and would simultaneously have weakened to plastic to the point that, instead of creating a hard bond, you created a soft one, and buoyancy just took over after a few weeks, tearing the pieces off and sending them to the top.
My suggestion would be to place in your fish tank only items designed to decorate the tank, and even those should be carefully cleaned per instructions. Fish get their oxygen from the water. Toxins leeching into in the water will poison them just as surely as large open vats of toluene-type glue in your home will eventually overcome you. And goldfish are hardier than most.
Posted by Anonymous on Wednesday, January 14, 2004 10:52 AM
It would be if you poured it into your lungs. Remember, fish breathe water.
Posted by cassibill on Wednesday, January 14, 2004 12:33 PM
aquarium sealer might be an interesting glue.
Posted by Anonymous on Wednesday, January 14, 2004 10:47 PM
Well, guys, whatever I do next, it won't be placing models in the fish tank.
My 10 yr old Daughter has already said so, they WERE her fish Dead [xx(]
Thank's for all the responses Thumbs Up [tup] - Happy modeling!
Posted by Anonymous on Saturday, January 24, 2004 10:57 AM
Well, if glue will kill the fish, how about a die-cast model? They seldom use glue to hold parts together (unless you use a high-end die cast - wish I doubt!).
Not much fun since you don't actually build it, but it would look good...
Posted by gregers on Saturday, January 24, 2004 2:32 PM
i had an aircraft carrier in my tropical aquarium for about five years. it was an early one that was glued with airfix tube glue and painted with humbrol enamel, never had a problem with the fish dying either (cept when one of the fish that turned cannibal) the only problem was cleaning it....... yuch. i changed the water fairly regularly tho hope this helps.
Greg
Why torture yourself when life will do it for you?
