Rubber Tires and Decals
Posted by IBuild148 on Wednesday, September 22, 2010 3:06 PM
Has anyone used decals on rubber tires? I am close to finishing my '66 Chevy and I have 2 options for the tires:
1. Black WallsNo
2. White Walls. Here is a poor quality pic of the tire and decal sheet.
IMG_0007-1.jpg picture by xlt2002ms
I am thinking of doing a 1. Flat Coat on the "RUBBER" tire, 2. Decal Set, 3. Place the decal 4. Gloss Coat.
I am hoping someone has dealt with this before and can lead me in the right direction.
Thanks
IBuildOne48
Teach modeling to youth!
Scalefinishes.com
http://i712.photobucket.com/albums/ww122/randysmodels/NMF%20Group%20build%20II/Group%20Badge/NMFIIGBbadgesmall.jpg
    April 2005
Posted by wing_nut on Thursday, September 23, 2010 5:55 AM
I've never put a decal on a tire but a flat coat under a decal = silvering.  Don't see what it's being done on would make a difference.   Maybe try setting the decal with Future by itself.  I do that all the time.  The nice thing is, after is has dried real well, the excess Future can be wiped away with a cotton swap dampened with alcohol.
Marc
Posted by Don Stauffer on Thursday, September 23, 2010 8:44 AM
I've had very poor luck with water slide decals on tires, but some kits have dry transfer lettering, and while harder to apply, I've had good luck with their appearance. I much prefer them to water slide.
    November 2006
Posted by buildit on Monday, October 4, 2010 7:00 PM
I've had real good results putting white letter decals on tire sidewalls.  I start by applying a couple of good coats of Future and letting it dry thoroughly, then apply the closely trimmed decals using Solva-set to help settle them into tire.  Once the decals have dried thoroughly I apply another coat of Future to seal them up.  After drying, I give it a couple of final coats of clear flat.  For what it's worth, there it is....lol
    April 2010
Posted by Ripcord on Monday, October 4, 2010 8:17 PM
Are they letters or white walls?  If its a white wall, how about trying to tape the center and then use a circle template to airbrush the white walls.  Just an idea...   Smile
Posted by IBuild148 on Monday, October 4, 2010 8:43 PM
buildit and Ripcord - Thanks! I used the kits supplied "white walls" and they turned out fine.
Here is the link to the completed build:
/forums/t/130904.aspx
IBuildOne48
Scalefinishes.com
