Chrome trim on thin parts.
    February 2004
Posted by chris hall on Tuesday, October 26, 2010 10:41 AM
I don't usually do model cars (two in the last decade, including a Wallace & Gromit Anti-Pesto van). However, recently on eBay there was this Tamiya Mini Cooper at such a good price that it would be rude not to have a bid...
Anyway, it's a very fine kit, with good-quality chrome trim on all the larger chromed parts. On some of the smaller, thinner, chrome-plated parts on the real thing (window edge trim, bodyshell edge, no chrome is provied.
What thoughts do people have on representing these thin chromed parts. Ideas that occur to me include:
  • Chrime silver paint, painted freehand with a thin brush;
  • Chrome or standard Bare Metal Foil;
  • Bright silver marker or gel pens
  • Mask bodyshell or lgazing, spray Alclad II Chrime over gloss black base coat.
All these have worked for me on small silver details on non-car kits in the past. Is there a consensus on what works best in these situations on model cars?
TIA,
Cheers,
Chris.
Cute and cuddly, boys, cute and cuddly!
Posted by VanceCrozier on Tuesday, October 26, 2010 10:49 AM
Works best? I've had pretty good luck with silver paint-pens, but I suspect the bare metal foil is probably the best-looking option.
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
Posted by Don Stauffer on Wednesday, October 27, 2010 8:41 AM
Among my car building buddies we use a mix of alclad on some parts, Bare Metal foil on others. If a part is an integral part of body or some other part, like windshield frame, it gets BMF. If a standalone piece like a bumper, Alclad.  Rather than the pens, which I have used in the past, I do very small parts, or touch up flaws on kit chrome, with Floquil "Old Silver."
Another trick- on racing cars and show cars, kits often finish in chrome parts that are polished aluminum on the prototype. I spray these parts with Testors dullcoat to get a polished aluminum look.
    February 2004
Posted by chris hall on Sunday, October 31, 2010 12:02 PM
Thanks, guys. I'll use chrome BMF on the window frames, and chrome Alcald II on the body trim.
Cheers,
Chris.
    July 2010
Posted by Mad-Modeler on Sunday, October 31, 2010 12:09 PM
BMF on the window frames will work well.
On my Rally Mini I also used it for the body trims, very narrow precut strips applied and worked in than trimmed.
Considered masking for Alclad but the trim is less than 1mm = a pain to mask.
    February 2004
Posted by chris hall on Sunday, October 31, 2010 3:07 PM
Good point re the body trim, but I was planning on spraying the bodyshell first, then doing the chrome trim. I spray aircraft canopies all the time, so masking off areas 1mm wide is no big deal.  By contrast, getting bits of BMF less than 1mm wide to stick in place can be.
Cheers,
Chris.
Posted by Don Stauffer on Monday, November 1, 2010 8:13 AM
chris hall
Cheers,
Chris.
The BMF does not need to be the same width as the trim stripe- it can be wider.  This is generally how folks do it. Cut a strip several mm wide, apply it, and nestle down carefully along the edges with point of a toothpick or end of fingernail.  Then, take an X-acto with #11 blade and cut along the outside of trim.  Remove excess chrome and it will look fine.
    September 2009
Posted by Cobra 427 on Sunday, March 13, 2011 7:07 PM
Bare Metal Foil? I take it that BMF stands for that. Avoid it like the plague!!! It's crap, and it looks unconvincing. Use the Alclad paint on all your models - it looks the most realistic. The foil just looks dull, and cheap! That's stuff made for junk yard cars, and RC cars that will be crashed. You want your models to look convincing - not amaturish! As soon as I can get some Alclad, or Killer Chrome, I'm going to finish all my cars with it. I want my vehicles to look as good as physically possible with the utmost realism as I can with what I have, and can do with the skills, and available materials on the market. Foil just doesn't cut it for me anymore!
~  Cobra Chris
Maybe a picture of a squirrel playing a harmonica will make you feel better?
    February 2004
Posted by chris hall on Monday, March 14, 2011 7:18 AM
I think that's possibly a little unfair on BMF. While I would accept that Chrome Alclad II can, with skill and practice, give a very realistic result, I think the same can be said for BMF. This Hsaegawa 1/48 F-86F was covered almost entirely with BMF:
and so were the shiny bits, especially the hub caps and ligght fittings, on this Airfix Anti-Pesto Van:
Cheers,
Chris.
