need help!
    December 2010
need help!
Posted by ledsepplinrocks on Wednesday, December 1, 2010 7:39 PM
i need some suggestings because i bought a 1970s model mach 1 mustang and i screwed up and didn't put enogh primer and the model didn't turn out that well
but i just recently bought a revell ferrari enzo that has a skill level 3 to it and i was wondering if anyone could give some suggestings on what primer to use and what clear coat
if u have any other sugesting please reply
    March 2010
Posted by shoot&scoot on Wednesday, December 1, 2010 7:51 PM
You didn't say how far along the model was when it was painted but if you haven't put any clear parts on it yet the paint can be removed by soaking the model in automotive brake fluid for a few minutes and gently brushing off the dissolved paint with a fine hair brush.
My friend Panzerjager is back into building car models with a vengeance and just received a Model A gasser that someone had painted with what appeared to be red Rustoleum.  After a good soak in brake cleaner and some gentle brushing it was restored to bare plastic with no discernable ill effects.  I was totally amazed and have filed this technique away for further possible use.
        Pat.
Posted by Don Stauffer on Thursday, December 2, 2010 8:58 AM
I use either Krylon primer or Duplicolor primer (the latter is from auto parts stores and is for painting full size cars. I find enamel easier to get a good gloss coat, so I use enamel, and thus clearcoat with Testors glosscoat.  I have also used polyurethane clear gloss varnish thinned way down.
    March 2008
Posted by EasyMike on Thursday, December 2, 2010 9:30 AM
What type of paint did you use on the Mustang?  Ammonia will strip acrylics; Easy Off oven cleaner (stinks) or automotive brake fluid will strip enamels without harming plastic.
Personally, I wouldn't worry about paint selection for the Ferarri until you've corrected the Mustang.
Smile
    March 2008
Posted by EasyMike on Thursday, December 2, 2010 9:31 AM
Smile
