Etched parts help please
    August 2003
Posted by wasjr on Friday, December 24, 2010 12:41 PM
Just purchase the new Revell Kurtis Kraft  Midget. It has photo etched parts
Outstanding kit
I have never work with these type of parts before before
What do I do
Posted by Don Stauffer on Sunday, December 26, 2010 8:46 AM
There are three pieces, two hood straps and the steering wheel spoke assembly.
The instructions show the installation of the hood straps pretty well, in one of the last steps. You bend the top in 90 degrees, insert through the hole in the hood and glue in place.  Hood should already be painted by this time.
The PE spokes are an option.  The kit provides a one-piece steering wheel with spokes and rim cast together, but the PE version is much nicer.  There is a separate rim for the PE spokes- glue the spokes to the bottom of that rim, then insert the optional shaft through from the top and glue.  Paint the rim (I painted it after gluing spokes in place, so I would not have to scrape paint off gluing surface).  Now install.
Gluing in all cases is not difficult and I used CA.
    August 2003
Posted by wasjr on Monday, January 17, 2011 4:45 PM
Thank you for the help
I was wondering how to get off and attach to the plastic parts
When i saw the etch parts in package backed off and  I put it up till I found out more
I have three or the v-8 and just ordered 3 offy editions
Thinking of doing a diorama of a  40s-50s starting field
I  also have the indy version and old revell midget but have lost tires somewhere and been unable to locate tires to fit it
