Detailing undercarriages & mechanical parts
    January 2011
Posted by dan o'war on Thursday, October 6, 2011 7:55 PM
Hey all.  I am just getting back into the world of modelling after a very long hiatus, and find myself unsure of where to get started on certain things.  I've read a whole bunch of research material and guides, faqs, etc, and feel that the internet and fine forums such as this one have prepared me to make a perfect finish on my cars, but one thing that's always got me a little bit is the overall process for some of the lesser-seen areas of a model car -- the chassis, axles, exhausts, crossbraces and so forth (all the fiddly mechanical pieces).  After so long out of the saddle, I honestly just don't remember where to get started, and so I was hoping to put out a bunch of questions, if nobody minds!
When starting out a kit, what is the best way to prepare these pieces?
Do you prime them and paint them while on the tree?  If so, how do you handle the smoothing-out and painting of the area that was still attached to the sprue after it's been removed?
Do you cut them and sand the sprue areas before priming and painting?
Do you put together sub-assemblies of things before priming and painting?  If so, to what degree of assembly do you go before painting?
Do you brush certain things, or use an airbrush as much as possible?  What things are typically better brushed vs. airbrushed?
On vehicles where most of the stuff down there is pretty much just flat black, how can you make the underside look good, or at least not quite so uniform?  This goes as much for vehicle interiors as it does the undercarriage / engine bay...
Sorry for all the noob questions here, but I had to ask!  Thanks very much, all!
Posted by Don Stauffer on Friday, October 7, 2011 9:02 AM
I usually prime the whole sprue.  Whether I cut the parts off of the sprue depends on how hard it will be to hold the part. If there are holes or stubs that can be grabbed with a clothespin, I will cut it off the sprue to paint.  I usually paint these parts with a rattlecan. If the part is very small I might use a brush.   I certainly build up sub-assemblies, and if the parts are all the same color I will paint as a subassembly.  If I paint while on the sprue, then I accept the necessity to touch up the point where I cut it from the sprue with a small brush or toothpick.
Rather than flat black, Testors makes, in the Model Master line, a Black Chrome, which to me makes a better chassis/frame paint than flat black. It is a semi-gloss black.
    January 2011
Posted by dan o'war on Friday, October 7, 2011 9:42 AM
Thank you for the feedback!
As for the sort of color-monotony of the undercarriage though, how do you spice it up a bit?  Just with weathering, or do you paint small details (bolt-heads and what-not), or is it pretty much common practice to just paint just about everything down there the same color and call it a day?
Thanks!
    October 2011
Posted by Alyn on Friday, October 7, 2011 1:31 PM
I've primed small parts both on and off the sprue. You can prime them on the sprue and then remove and finish each part. Reprime as required. I have a clothes hanger with adjustable clamps for hanging pants. I use the clamps to hold a strip of masking tape, which in turn holds my small parts. The hanger can be held in one hand while you paint with the other, or the hook can be straightened and slipped into a homemade sleel/aluminum tube mount.
In the automotive world, you have to decide whether to paint the chassis clean and bright (suitable for the Barrett-Jackson chassis cam, or worn and weathered as it would appear if street driven. In either case, black primer makes a good base color. Dust over the black with Bragdon powders in shades of gray and brown, then follow up with dry brushing in gunmetal gray to bring out the bolts and other details.
https://skydrive.live.com/?cid=f9465c064bbdafed#cid=F9465C064BBDAFED&id=F9465C064BBDAFED%21489
https://skydrive.live.com/?cid=f9465c064bbdafed#cid=F9465C064BBDAFED&id=F9465C064BBDAFED%21664
For added interest, silver can be used for the fuel tank and in rare cases (newer Corvettes as an example), suspension arms. Bright colors can be used for shock absorbers and swaybars, coil springs if you're feeling spunky. Aluminum drive shafts are rare, but some competition cars and late model vehicles use them. The underside of the engine will also add some color and detail.
Posted by Don Stauffer on Saturday, October 8, 2011 9:04 AM
dan o'war
Thanks!
Springs are frequently different colors than the frame.  Coils are painted, sometimes a gloss black.  Leaf springs are usually a treated steel color.  There may be lines and hoses under there, usually unique colors.  Exhausts need to be painted with a "burned" patina.
    January 2010
Posted by CrashTestDummy on Monday, October 10, 2011 4:12 PM
Leaf springs will also tend to have a little coarser surface than other chassis parts, so they'll grab more dirt.  Also, since the spring leafs will rub against one another as the chassis moves, they may also have a slight patina of rust or dirty rust along the leaf joining points.  A wash of thinned rust will do well here.
Don't forget there are aftermarket coatings you can use to spice things up a bit.  Undercoatings are almost always a flat, while any factory coating will tend to be a semi-gloss.  And depending on the manufacturer, certain parts, or the while chassis won't even be painted.
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
