stripping chrome from parts
    May 2011
Posted by Lucky 7TH on Wednesday, January 11, 2012 2:40 PM
I would like to know how I would go about stripping the chrome from plastic model parts...any household chemical ideas???
    March 2011
Posted by jb4406 on Wednesday, January 11, 2012 3:01 PM
I've had good success using "Westley's Bleach White" tire cleaner. Pour some in a container deep enough to submerge your part(s) in & let soak overnight. Wash parts off w/ clean water, & scrub any chrome left gently w old tooth brush while rinsing. Works for me every time.  Make sure you wear rubber gloves while handling this stuff though, it can be tough on skin if left in contact for prolonged periods. A respirator isn't  a bad idea either if working w/ this stuff in confined area.
"The difficult, I do  right away. The impossible will take a little longer."
    May 2003
Posted by Robert92562 on Wednesday, January 11, 2012 5:09 PM
fresh clorex bleach works best for me.
fox
    January 2007
Posted by fox on Wednesday, January 11, 2012 8:55 PM
Ditto on the Clorox Bleach. Fill a small mason jar with enough to cover the plastic parts and let sit overnight. Remove the next day and scrub with mild dish soap and an old toothbrush. Been doing it for years and it works fine.The Clorox can be used over and over again.
Jim Captain
 Main WIP:
Posted by Don Stauffer on Thursday, January 12, 2012 9:14 AM
I've had pretty good luck just priming and painting these parts without stripping the chrome.  Use a toothy primer like Krylon or an automotive primer.
    April 2009
Posted by Cadet Chuck on Thursday, January 12, 2012 9:47 AM
I've had good luck with good ol' Chlorox laundry bleach.  Just let the parts soak in straight bleach for a couple or three days.  It will magically dissolve away.
Careful with that Wesley's tire stuff.   It will peel your skin off!
    November 2011
Posted by 70gtvert on Thursday, January 12, 2012 10:20 AM
Easy Off oven cleaner, the lye formula version (they have a "newer" version the also sell without lye, but the original is always sold next to it.). Strips plastic of chrome in just a couple of minutes. Another plus with this is that it will also strip enamel paint off of plastic quickly without harming the plastic. Also strips clear lacquer but if the lacquer is in colors it takes a little longer.
    February 2008
Posted by enemeink on Friday, January 13, 2012 10:20 AM
i used the bleach method just the other night on my Revell DTM Mercedes. took only an hour to get the plating off, however it did look like there was a gloss coat over the parts once i pulled the parts out and let them dry after rinsing.
"The race for quality has no finish line, so technically it's more like a death march."
