Repairing windshields.....
    January 2012
Posted by tyhe314 on Monday, February 20, 2012 12:06 AM
So I was trying to glue some led lights on last night with Testors liquid cement (comes in a toothpaste tube) and I unintentionally got some of the glue on the windshield (to my dismay). I scraped it off but I noticed that the glue "melts" the windshield leaving an indentation. Of course I'm furious after all the time I spent on the model and $80 worth of model, lights, and paint. Does anyone have any recommendation on repairing the dents in the windshield?
    September 2011
Posted by Morbane on Monday, February 20, 2012 1:47 AM
Unfortunately there is no effective repair for the glue on clear plastic - the 'melt' goes through to at least the center of the plastic.
Your best option is to try and order the piece individually and re-attempt the attachment with less glue or to use the testors precision glue, which dries really fast - I have found that it seems to bond firmly in seconds with parts that fit accurately.
Good luck.
Posted by Don Stauffer on Monday, February 20, 2012 8:40 AM
You didn't mention what car, so don't know if this will work or not.  But with a flat windshield, or one with a single curvature, you can replace the kit windshield with clear styrene or acrylic, available at many hobby shops. I'd trace the existing windshield on a piece of paper, cut it out and use that for a pattern to lay out the sheet transparent plastic.
Because of the mess solvent glues make, I always glue around windows/windshields with either microglaze or epoxy.
    January 2012
Posted by tyhe314 on Monday, February 20, 2012 9:22 AM
Ya sorry I'm finishing up a Lexus lfa. I thought about replacing it with a piece of styrene but it is connected to all the windows so think my only option is to order the sprue tree
    December 2009
Posted by MarkDW on Monday, February 20, 2012 1:10 PM
I have had some luck sanding windshields out with successive finer grits and then using Novus plastic polishes until the glass is near perfect on a 1960 Vette.  Or you can paint bird plops on the glue mark and make super realistic weathering effects! LOLBig Smile
    December 2009
Posted by MarkDW on Monday, February 20, 2012 1:12 PM
    December 2004
Posted by panzerpilot on Monday, February 20, 2012 1:14 PM
Try contacting the manufacturer? I've had pretty good luck with getting replacement parts over the years that "dissapear" or otherwise get fouled up. It usually takes a while, though.
-Tom
    August 2008
Posted by tankerbuilder on Tuesday, May 29, 2012 6:22 PM
You can still seperate the windshield from the rest of the glass.You MUST be careful though.Then get in the habit if you have a good fit , of using white glue or TESTORS window maker to glue the clear parts in place.SORRY about the BOO-BOO.   TANKER-builder
    June 2010
Posted by OctaneOrange on Wednesday, May 30, 2012 1:00 AM
MarkDW
As mark suggests, if you can sand the mark out (assuming not too deep to sand out). then use a polishing kit of increasing grades until you restore the clarity of the part.
start at 2500, 3000, 4000, 6000, 8000, 12000, then Novus 3, 2, 1. don't skip any step and sand always in the same direction.
    January 2010
Posted by 101stAirborne on Saturday, June 2, 2012 8:59 AM
if it is a revell kit you can just reorder the part no questions asked. Just go to Revell.com
Models on the bench:
Too many to count!
