Removing paint from a car body
    January 2010
Posted by 101stAirborne on Saturday, March 10, 2012 2:28 PM
Does anyone know how to remove paint from a car body? I want to take all of the enamel paint off but I'm not sure how. The pain job is really bad and I want to try again. If I put it in a bucket of mineral spirits will it ruin the plastic?
Thanks, Ryan
Models on the bench:
Too many to count!
    November 2010
Posted by Bigb123 on Saturday, March 10, 2012 2:58 PM
Put the parts in a large ziploc , spray in some easy-off oven cleaner, let soak for an hour, then scrub the remaining paint with an old toothbrush under cold running water does the trick for me.  You may have to repeat the cycle to remove stubborn paint in corners and such.   I do, however, not model cars, only planes and ships, but the process should work since the plastic is the same no matter what kind of model it is.
    January 2010
Posted by 101stAirborne on Saturday, March 10, 2012 3:27 PM
Thank you!
Too many to count!
    June 2010
Posted by OctaneOrange on Tuesday, March 13, 2012 11:01 PM
i used to use Easy Off, but it seemed to not really work very well anymore. i think they changed the formula. i now use brake fluid in a sealed tupperware type lunch box sized container. you can sink the whole body into it at once.
    May 2011
Posted by Oom Leeu on Wednesday, March 14, 2012 9:16 AM
Hello
I had the same problem with my 1: 12 scale Revell 57" Chevy the silution was BRAKE FLUID  ,
Took a plastic container and submerged the body in brake fluid  overnight next day rinsed with cold water and fine brush to get the paint out of the nooks and crannies perfectly stripped model washed it after that with dishwashing soap and rinse again, let it dry and do the painting again ...... to safe the used brake fluid drain it through a cooking oil filter and store in a glass container for future use.
Posted by Don Stauffer on Wednesday, March 14, 2012 9:23 AM
I also recommend Easy-Off.  Just had to remove paint from several body pieces of an Italari Chrysler Phaeton.  I first tried some Testors stuff made for model enamels and it didn't work that well. A friend lent me a can of Easy Off to try. First time I tried it.  Had to apply twice, but it did a fine job of removing both the Testors Enamel and the tenacious Krylon primer.
    January 2012
Posted by Mrakulous on Wednesday, June 27, 2012 9:56 PM
I used some dollar store toilet bowl cleaner.  But only for removing chrome plating.  Took about 15 minutes.  Not sure about paint though.  Brake fluid is a great idea.
    January 2011
Posted by Bugatti Fan on Wednesday, September 26, 2012 1:21 PM
Brake fluid or oven cleaner appear to be most widely used, and both have worked for me. I'm a UK modeller and the brand of oven cleaner I use is named 'Mr Muscle, so maybe the same brand is available in the States as well.
    April 2009
Posted by Cadet Chuck on Wednesday, September 26, 2012 1:48 PM
Better stock up, before the EPA bans all of that stuff!
Wink
    August 2007
Posted by DUSTER on Saturday, September 29, 2012 6:15 PM
  I use  Simple Greenhttp://www.simplegreen.com/products_all_purpose_cleaner.php
 an all purpose cleaner sold in the US and Canada, it will work on all the paint types I have tried it on, including Alcad II.
It may take a day or two to work but the lesser toxicity, over brake fluid  and the minimizing  of damage to your skin from oven cleaner contact ; all that makes it my first choice.
But what ever you settle on, use it safely  & wisely; after all if the product removes paint its got serious stuff in it.
Steve
