1925 Ford Model-T Tow Truck
    October 2011
Posted by Alyn on Saturday, April 6, 2013 3:58 PM
I started working on this last fall. The chassis will eventually be part of a Model-T based tow truck, hence the solid rubber tires on the rear.
The model was started from the AMT Double-T kit, but has many more scratch built parts and details added. The metal rod was eliminated in the front axle. Brass was used to create steering knuckles, tie rod and drag link for fully functioning steering right up to the steering wheel. Brass was also used for steering column, throttle and spark controls, hand brake lever, brake rods and control pedals. Other details are made from styrene and aluminum.
Green for the engine is a mix of Testors green enamel toned down with some black and white. Wheels were primed and then painted with a base coat of pale yellow enamel. this was followed by artists oils to create the faux wood grain. Once fully dry, the oils were sealed with semi-dull coat. Wheel rims are sprayed with Tamiya green synthetic lacquer and Floquil black and silver for details.
This is an earlier shot of the chassis with the scratch built wrecker boom in the back ground. Battery and muffle/exhaust pipe and running board braces were also made from scratch.
thanks for looking
    December 2011
Posted by Scratchbuilder725 on Saturday, April 6, 2013 9:33 PM
Really cool! keep us posted!
    July 2012
Posted by littletimmy on Monday, April 8, 2013 11:39 AM
God how I love the old trucks !!!   Theres something to be said for a vehicle that you dont have to replace compooter (computer) Chips just to start the damn thing ! Nice job !!!   Cant wait to see the cab on !
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
Posted by rangerj on Monday, April 8, 2013 2:16 PM
Super build so far, keep posting your progress. What color did you use for the engine and trans? Was it commercially available or did you mix it? IIR that model year was started with a hand crank and if you did not do it right you could get your arm broken. I do not recall what year Henry Ford finally agreed to pay royalties and use electric starters. Anyone? Again, IIR correctly that model year had cable brake activation. What year did the brakes become hydrolic? IIR spark advance was also manual and done with a lever on the steering column. The early windshield wipers were also manual, then vacuum operated and much later electric. Tires were horrible and it is very common to see those old cars with two spare tires. The gas feed to the engine was by gravity and if you had to go up an incline you would do it in reverse. Anyone know what year colors other than black became available? It was sometime around the vintage of this model subject IIR. I do not know if it is true but someone told me that one of our modern cars has more sophisticated computer power than the Space Shuttle". I look forward to seeing this build, please share it with us. Neat stuff!
    July 2012
Posted by littletimmy on Monday, April 8, 2013 3:37 PM
The electric starter was concieved by the guys at Cadillac.  A woman attempting to start her Cadillac broke her arm when the crank caught and spun with the crankshaft. This was in 1915 but my mind is full of paint fumes and I may be wrong. Ford couldnt stand the thought of  paying the compitition  ( especially  Cadillac ) for the rights to what became "standard " equipment on all cars.
    October 2010
Posted by Bob H. on Monday, April 8, 2013 5:01 PM
That looks really neat !!! Thanks for taking the time to post it and PLEASE--- keep us updated.      Bob
    June 2009
Posted by Guney on Monday, April 8, 2013 5:30 PM
Good work so far...:)
    June 2010
Posted by OctaneOrange on Tuesday, April 9, 2013 1:24 AM
this looks excellent and is almost a model in itself. at what point do you abandon a kit and just build everything from scratch?
    October 2011
Posted by Alyn on Wednesday, April 10, 2013 11:55 PM
thank you all for the kind comments. I've always thought the Model-T was a pretty cool old car, but now that I've done some research for this build, I love these old things. The beauty is in the simplicity.
fangerj, the engine and tranny are painted with good old Testers enamel in the square 1/4 oz bottles; not my first choice for paint these days, but it was the only green on my shelf. I mixed in a bit of black and white enamel to tone it down.
From what I've read, Ford started offering an electric starter around or after 1918. This kit did not come with a starter, generator or battery. I scratch built each of these for some added detail. I don't know when Ford offered alternate colors for the T, but mine will boldly go with a green body and black fenders.
Octane, I wish it was a "model in itself". That is, I'd like to stop right now and call it dne. I really like the way the chassis came out and hate to cover it up with a body. But I will :)
I love the details, so there's always some scratch built parts in my models. With an engine consisting of only six parts, some scratch building is pretty much guaranteed.
Here's  a few more pics showing some of the build progress.
Brass used for control pedals:
Molded-in radiator pipe was ground away, then the cylinder behind it was shaped back to normal. The replacement pipe is brass, with yellow heat shrink tube for hose and aluminum foil for hose clamps. Plugs are 26 ga insulated copper wire.
Brass used for steering knuckles, tie rod and drag link.
The steering column is an aluminum tube with a brass shaft inside. Brass end pieces soldered on each end of the shaft. Brass was also used for the spark and throttle controls
running board bracing added with Plastruct styrene rod
    October 2011
Posted by Alyn on Thursday, April 11, 2013 12:39 PM
I meant to include this pic of the steering components prior to paint
and here's some recent paint work
    October 2011
Posted by Alyn on Saturday, April 13, 2013 11:54 AM
these pics were meant to be with the previous post, but didn't show up.
fenders are black, the rest of the body is green. Here's the tub
and the pickup bed. As you can see, this will be a tow truck. The wrecker boom is scratch built from Plastruct styrene angle, brass and aluminum.
fox
    January 2007
Posted by fox on Saturday, April 13, 2013 1:12 PM
Outstanding work. Toast Will be watching for more pics.
Jim Captain
 Main WIP:
Posted by rangerj on Sunday, April 14, 2013 12:49 PM
Drag link steering rods made from brass? WOW. Nice work. Are those grease fittings I see on the joints? (LOL) I have a 1/16 scale 31 model A Tudor I have been wanting to build and you have provided some great ideas for kit enhancement.
    July 2009
Posted by Back to the bench on Sunday, April 14, 2013 10:21 PM
Wow awesome work! Love the subject and your scratch building skills are adding outstanding realism.
Gil
    June 2010
Posted by OctaneOrange on Sunday, April 14, 2013 10:54 PM
Alyn
although Henry Ford said famously "Any color so long as it's black", they did in fact offer the T in many different colors.
    August 2007
Posted by DUSTER on Monday, April 15, 2013 1:35 AM
Not one to be left out , I too, join in the praise  of your skill.
Steve
    October 2011
Posted by Alyn on Thursday, June 27, 2013 9:38 PM
Finally got around to getting some pics of the completed truck suitable for posting
Rear view showing the tow boom and related kit
Top off, front view showing the hand carved brass radiator cap with clear styrene site glass
Weathered leather seat, scratch built dash details and door latch. The windshield is real glass cut from a microscope slide.
thanks for your interest and great comments. Very much appreciated.
Alyn
    July 2012
Posted by littletimmy on Thursday, June 27, 2013 10:43 PM
I'm tempted to cry "foul" and say you cheated and bought it from the Franklin Mint  but theirs dont look that good. Well done!!!!
    October 2011
Posted by Alyn on Sunday, June 30, 2013 1:38 PM
Thanks, Tim.
I'm going to assume that being compared to Franklin Mint is a compliment :)
    October 2010
Posted by Bob H. on Tuesday, July 2, 2013 8:23 PM
Great build. Thanks for posting it.                   Bob
Posted by Jim Barton on Thursday, July 4, 2013 3:12 PM
What a gorgeous model and something different!
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
    October 2011
Posted by Alyn on Thursday, July 4, 2013 7:49 PM
Thanks, guys. I really appreciate your interest and encouraging words. This truck has certainly turned into one of my personal favorites.
    May 2004
Posted by f8sader on Friday, July 5, 2013 3:14 AM
Indeed, thanks for posting this!  Taking the time to explain your methods is very inspiring for me as I am sometimes afraid to take the lid off the box and start a kit for fear I'll muff something up!  Looks like you have experience with these old trucks as you used the addition of solid rubber tires.
Lon-ski
    May 2014
Posted by misterNNL on Thursday, May 1, 2014 3:29 PM
Do you have in-progress photos of the wrecker assembly available ? I am wokking on a wooden cab TT with a 1915 Weaver Auto Crane hand crank wrecker boom assembly.
    December 2013
Posted by CodyJ on Tuesday, May 6, 2014 11:49 PM
Wow that is very nice.  Love the brass work and color you chose. The entire thing is done beautifully!
    October 2011
Posted by Alyn on Sunday, May 18, 2014 11:44 AM
Here's a few pics of the boom in progress.
I started by constructing a solid base in the pickup bed using Evergreen angle
more angle was used for the boom and A frame. to curve the boom, some slits were cut and then glued after the angle was curved around an old film canister. I wrapped the canister with tape to keep the styrene glue was sticking.
I found some old gears in my scrap box, one with an extended hub to use as a cable spool and a smaller one for the pinion. Brass and aluminum was used for shafts as well as for the grab handle on top. Rivets are railroad items from Grandt LIne.
More detail was added in the way of plastic bracing and brass support rods. A Scale Hardware bolt and nut were used to allow for boom height adjustment. All brass parts were dipped in Blacken-It.
A brass shaft at the end of the boom holds the yoke and pulley. I machined the pulley from some aluminum rod and then formed and soldered up some brass for the yoke.
The chain was some I had laying around and the metal hook was again a model railroad item that was filed down to a suitable shape. With the exception of the blackened brass, everything was covered in black primer. The whole assembly was weathered with chalk powders and highlighted with a Tamiya weathering set. Hope that's what you were looking for.
    May 2014
Posted by misterNNL on Sunday, May 18, 2014 9:31 PM
Thanks for posting these in-progress photos of the boom under construction.That is exactly what I wanted to see.Those will help me a lot with my project !
    October 2011
Posted by Alyn on Monday, May 19, 2014 11:12 PM
Good luck with your project. Be sure to let us see how it turns out.
Sometime after posting the finished photos of the truck, I decided to add a few more details that had been planned but didn't make it in the first rendition. First off is the roof. I wanted something a little different, so scrounged up a second roof and cut the back off. On my old Jeep CJ7 this was called a bikini top. I scratch built the top bows out of brass rod and tube. What will be the rear straps that keep the top tight are also brass.
After seeing the hollow seat cushion bottom a zillion times, I addressed that as well. I bent up some springs out of enameled copper wire and used some dryer lint for the stuffing. You can also see the top mounts in this picture.
I also built a toolbox using some basswood and stryrene. The hammer, tire iron and screw driver are scratch built. The wrench is a laser cut part shot with primer, then black and finally Alclad chrome. There's a bunch of wrenches in the box not visible in this shot.
I also scratch built a tool tray for the top of the box, but ended up not using it. The tray is made from brass sheet and tube.
    October 2011
Posted by Alyn on Monday, May 19, 2014 11:25 PM
Here's the most current photos of the completed truck
rear view; added some chain and some weathering on the tow bar.
and one more
Posted by Jim Barton on Tuesday, May 20, 2014 2:49 PM
Way to go!
