Stripping chrome plating?
    July 2003
Posted by Kugai on Sunday, February 22, 2004 2:32 PM
I have the Batmobile from the Tim Burton Batman movies and the chrome is in all the wrong places. I want to get rid of the stuff, but the usual "soak in bleach" approach hasn't worked. Instead of the usual 10 minutes, it's been over 2 WEEKS and most of the stuff is still on!
Is there something else I can use that won't damage the plastic, or am I stuck waiting for who-knows-how-long for the bleach to work?
http://i712.photobucket.com/albums/ww122/randysmodels/No%20After%20Market%20Build%20Group/Group%20Badge/GBbadge2.jpghttp://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
Posted by Woody on Sunday, February 22, 2004 2:40 PM
You might try oven cleaner. Chrome plating on models is not the same as electro plating on metal. Parts are sprayed with clear base coat and placed in a vacum chamber. Vaporized aluminum is created and collects on the still wet base coat. As you can see almost anything that will safely strip paint from styrene can be used to strip the "chrome" from model parts.
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
Posted by Anonymous on Sunday, February 22, 2004 2:44 PM
I dilute Kitchen bleach with water in the ratio of 1:3 or 1:5 and than let the parts lie in it for 1~2hrs.
Toothbrush for hard to reach areas and I found that this worked well so far.
Posted by Woody on Sunday, February 22, 2004 2:53 PM
I just had a thought. What brand of bleach are you using? Not all bleachs are chemically the same. If you are not using it already may I suggest Clorox.
Posted by Anonymous on Sunday, February 22, 2004 3:51 PM
I use full strength clorox, and it works like a charm!!!
    July 2003
Posted by Kugai on Sunday, February 22, 2004 6:00 PM
I used Clorox, both straight and with about 3 parts water.
Posted by Anonymous on Sunday, February 22, 2004 7:26 PM
Guess, I should have read it more closely..Whistling [:-^]Whistling [:-^] I just got too excited to give out advice, I suppose. Whatever you do, DON'T use nail polish remover, it eats the plastic!! Sorry, I couldn't be much help.
    July 2003
Posted by lizardqing on Sunday, February 22, 2004 8:47 PM
That must be some strange chrome, I have never had a problem with Clorox. I hope it's not some new type they have come out with to keep us from useing something else.
Posted by Anonymous on Sunday, February 22, 2004 10:18 PM
I tried Clorox once out here & it failed, however, in the UK, a brand called Domestos worked within seconds.
Pete
Posted by Anonymous on Monday, February 23, 2004 1:19 AM
Bought myself a can of EASY-Off oven cleaner and tried it on chrome parts. It simply work like magic. Within seconds, all the chrome disolve almost immediately. Lucky enough to get it in ACE harware superstore in Malaysia. BTW, how much izit for a can in the US ?
Posted by Anonymous on Monday, February 23, 2004 2:35 AM
I use Clorox Cleanup. Takes about 10-15 minutes.
Posted by Anonymous on Monday, February 23, 2004 7:17 AM
I use a cleaner called Simple Green, takes off the stuff in about 30 minutes. Doesn't stink as bad as oven cleaner either.
Moderator
Posted by Matthew Usher on Monday, February 23, 2004 8:51 AM
I use Castrol Super Clean -- it's an automotive cleaner/degreaser. It comes in a big purple bottle and you can find it in auto-parts stores. It'll remove the chrome plating and the clear coat underneath. I just used it on the parts in Revell's 1966 GTO and it worked like a charm.
Make sure to follow the safety directions on the bottle, by the way.
Matt Usher @ FineScale Modeler
    July 2003
Posted by Kugai on Monday, February 23, 2004 1:54 PM
Thanks for the tips, guys.
As far as the chrome being some new formula resistant to removal, I suspect it may have been the bleach formula that's been changed. About 2 years ago, I built the Batmissile kit ( made by the same company at the same time as the Batmobile ) and the Clorox I had at that time worked in about 10 minutes.
    December 2003
Posted by Enzo_Man on Wednesday, February 25, 2004 12:03 AM
Castrol Super CLean all the way, baby! Yeppo, like Mr. Usher said, follow the directions! I accidentally got a drop on my hand and didn't notice it. After a while it started to burn. CSC only needs about ten minutes to do the job. The chrome will be liguidfied, vaporized-gone. Good lick, dude!
Aerodynamics is for people who can't build engines.
Posted by coldwar68 on Wednesday, February 25, 2004 8:38 AM
Oh yeah, gotta go with the Castrol Super Clean too. I used it to strip some chrome parts...worked like a charm. Good stuff!
Jerry
I can picture in my mind a world without war, a world without hate. And I can picture us attacking that world, because they'd never expect it. -Jack Handy
    December 2003
Posted by Enzo_Man on Thursday, February 26, 2004 1:39 AM
Whoops! I just noticed something-I mean good LUCK. Blush [:I]
Posted by Anonymous on Thursday, February 26, 2004 7:42 PM
"Spic'n Span" works for me !
