carpeting
carpeting
Posted by Anonymous on Tuesday, February 24, 2004 8:45 AM
anybody know how to make carpeting for the floorboard of my 69
chrys. thanks
Posted by Jim Barton on Tuesday, February 24, 2004 11:29 AM
I went to a fabric store and got cloth that would make good-looking carpet for my Jeep Cherokee. I had to go to about four or five different fabric stores before I finally found some cloth that "looked right" AND was the color I wanted without being too thick, so be prepared to break out the Yellow Pages, jot down some addresses and do a bit of driving around. I even brought the interior tub with me to the fabric store for testing various textures and thicknesses. For cutting the cloth to size, you'll need a good sharp small pair of scissors, so buy some at the fabric store if you don't already have them. Through careful measuring plus a bit of trial and error, I first made a pattern of the interior tub on graph paper, cut out various holes for consoles, seat fittings and the like, then after fine-tuning, transferred this pattern to a thin cardboard template (more durable then the graph paper). After further fine-tuning, I placed a piece of cloth on a flat beer box placed bottom-side up, securely pinned the cardboard template by poking LOTS of pins through the cardboard, cloth and beer box, then carefully used both the small scissors and an Xacto knife to cut out the "carpet." Again, this might take more than one attempt. After a futile attempt at using double-stick tape to attach the carpet (it doesn't work at all for permanently attaching the carpet but for doing it temporarily for test-fitting it works good), I removed the tape and carefully used tiny drops of super glue. Use the tiniest drops possible--too much will soak through the cloth. Do a small section of carpet at a time and make sure it's nice and flat.
I've also been to model car shows where the contestants used a product called "Fuzzy Fur" to replicate carpet. Used correctly, this looks even better than my cloth carpet (it might even be less work but I myself have never tried Fuzzy Fur as I'd never heard of the product until after my Cherokee was carpeted). Unfortunately, Fuzzy Fur is no longer being produced but with a little luck, you might find some in a good hobby shop or a model show. I think it's Detail Master or some such that also offers a similar product to Fuzzy Fur but I always thought the "carpet" made with this product looked a little too thick--maybe it's just the modelers that use it. There might be some other products I don't know about or other ways of adding carpet to model car interiors. Any takers?
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
    July 2003
Posted by lizardqing on Tuesday, February 24, 2004 2:12 PM
Welcome to the forum first off. You could try out the carpet flocking. There are a couple of different companies that make like modle masters and detail master. I used it on a Trans Am am after a few trys got it o come out great. Just practice a few times on something else before the model its self.
Posted by Anonymous on Tuesday, February 24, 2004 9:22 PM
I've used Model Master's flocking with pretty good success. I paint the inside of the interior tub with Woodland Scenic's Secenic Cement (which is pretty much just very-very-very-diluted white glue), dump in some flocking, and tap it around the tub to spread it out. Then I pour out the excess into a container and let glue dry. Then I repaint the interior with glue and pour my previously-extra flocking back in, and tap the tub to level it out and spread the flocking around. Empty out the excess again, and you're pretty much done. Painting the floor the "carpet" color helps out a lot. I'm pretty pleased with the results using this method.
    July 2003
Posted by lizardqing on Tuesday, February 24, 2004 9:58 PM
I used the paint that was the same color as the carpet to hold it down. Just put the flocking in while the paint was still wet and it worked just like glue with no bare spots. Just have to small pieces at a time to keep the paint from drying before you get the flocking on.
    December 2003
Posted by Enzo_Man on Tuesday, February 24, 2004 11:58 PM
Wuzzup, newcomer! I like to use carpet repair stuff that can be found at Wal-Mart's auto section. It's neat. It comes with several colors that you mix to get the right color. It even has a mixing chart. It's about 7 bucks. The only problem (very slight) is that for the new colors you make you need to find a seperate container for them. Hope this aids you in you'r quest.
Aerodynamics is for people who can't build engines.
Posted by Anonymous on Thursday, March 11, 2004 5:48 PM
For what its worth, I coat the floor, sidepanels etc...whatever you want to "carpet" with paper tape...the kind you find in the First Aid aisle. You can get it a few sizes. It stretches really well around corners...I lay it down before I paint. I'm not sure what exact look you're going for...but I've always been pretty happy with that method.
-jonathan
Posted by Anonymous on Sunday, March 14, 2004 1:07 AM
I have used a product from Scale Motorsport called "Faux Fabric" paint. It comes in grey or tan. When used, it leaves a textured surface. Several coats and the texture becomes more coarse, thus replicating that of carpeting. Once dry, you can paint over it to match your color scheme. Here's the link.
http://www.scalemotorsport.com/default.asp?paint
