Airfix 1/12 4.5 liter Bentley
    March 2014
Posted by kpnuts on Sunday, December 28, 2014 3:36 PM
Hi all, well I'm making a start on the Bentley today, first thin I notice that I'm a bit disappointed with is, when looking at the box art the front mud guard has not got much detail at all (I hope this is not a sign of things to come)
as you can see I have a load of rivets and nuts to scratch.
Posted by Don Stauffer on Monday, December 29, 2014 8:57 AM
One technique for the rivets is to use white glue- make a little puddle on scrap plastic and dip the end of a toothpick in the puddle and then touch that end to the plastic, leaving a little bump of white glue.  I do this after the first color coat, to avoid having to sand it.
    March 2014
Posted by kpnuts on Monday, December 29, 2014 12:53 PM
    July 2012
Posted by littletimmy on Monday, December 29, 2014 4:28 PM
Theres an easy way to cheat at rivets.  I just bite the bullet and buy Grandt line rivets.
They come in multiple sizes and stiles
I used to use them all the time for my railroad stuff
There is also a texturized sheet of decals for rivets but I dont remember who makes them.
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
Posted by Don Stauffer on Tuesday, December 30, 2014 10:49 AM
kpnuts
thanks for the tip, is it easy to keep the rivets the same size.
It does take a bit of practice, but not a lot. I'd suggest using some scrap material and putting down about twenty rivets or so to get the hang of it- how thick a puddle, how many rivets per dip.
    March 2014
Posted by kpnuts on Tuesday, December 30, 2014 3:05 PM
    June 2010
Posted by OctaneOrange on Tuesday, December 30, 2014 7:46 PM
kpnuts
i've not found many large scale kits that include more detail than your run of the mill 1/25 scale kit.
Posted by Don Stauffer on Wednesday, December 31, 2014 9:16 AM
I have had that kit in my stash for several years now- just can't bring myself to start such a massive project, particularly after having the Bus on my bench!
    March 2014
Posted by kpnuts on Thursday, January 1, 2015 9:24 AM
Hi all here is the progress so far I've put a 1/32 airfix kit and a 1/12 scale tamiya kit with it just to show how big this beast is.
http://i.imgur.com/ZLAfvRa.jpg
http://i.imgur.com/kPVXMk5.jpg
http://i.imgur.com/yhg6Z4O.jpg
http://i.imgur.com/sPmi3yn.jpg
http://i.imgur.com/9oAQADm.jpg
http://i.imgur.com/RiE0hY9.jpg
    March 2014
Posted by kpnuts on Friday, January 2, 2015 6:29 AM
Hi all I am so cross(mostly with myself for not testing it first) I received some humbrol acrylic chrome in a spray can today, and, eager to try it out I did it straight on the bentley engine, it clearly says acrylic on the can, and I primed the engine with humbrol enamel so there should have been no problem, anyway I started spraying and thought this smells very much like celloluse paint.
http://i.imgur.com/6aEWubT.jpg
now that is exactly the effect I would expect spaying cellulose on enamel not when spraying acrylic.
so now its getting the oven cleaner treatment, so take this as a warning.smell your paint first.
    February 2015
Posted by Bick on Friday, January 2, 2015 7:25 AM
Probably acrylic lacquer???
    March 2014
Posted by kpnuts on Monday, January 5, 2015 2:09 PM
    March 2014
Posted by kpnuts on Sunday, January 11, 2015 11:38 AM
    March 2014
Posted by kpnuts on Monday, January 12, 2015 12:53 PM
Hi all well here are the driver and admirers that will be going with this model.
They are from the Airfix London icon set, so I think very fitting.
http://i.imgur.com/y9Cm6vx.jpg
http://i.imgur.com/2hHKUAT.jpg
    September 2005
Posted by Sprue-ce Goose on Monday, January 12, 2015 2:16 PM
I can recall drooling over that kit when first released but cash restrictions keep getting in the way of buying my own example.
I am following your build up with pleasure.
Thanks for posting the photos.
    March 2014
Posted by kpnuts on Tuesday, January 13, 2015 1:40 PM
Well I got some rivets, nuts and braided hoses today for detailing her also found an old base from the Christie steam fire engine which was too badly broken to be repaired and anyway I've stolen lots of bits off it for other dios, so thought since its cobbled stones it would be good as a base for the Bentley. I've filled sanded and primed the people for the base as well.
http://i.imgur.com/wnW5wSD.jpg
http://i.imgur.com/mFKo7Uz.jpg
http://i.imgur.com/3Nd7FzS.jpg
http://i.imgur.com/cOD769a.jpg
http://i.imgur.com/5ff3YGq.jpg
    March 2014
Posted by kpnuts on Thursday, January 15, 2015 2:30 PM
    March 2014
Posted by kpnuts on Monday, January 19, 2015 2:55 PM
Hi all here is tonights update, I made the mistake for deciding to replace the plastic spokes with real ones, I am going to live to regret that decision
http://i.imgur.com/3aNHW11.jpg
http://i.imgur.com/1kdUXy8.jpg
http://i.imgur.com/Yhw3wgd.jpg
http://i.imgur.com/BYTdwzE.jpg
    March 2014
Posted by kpnuts on Tuesday, January 20, 2015 1:53 PM
Hi all well here is half of the first wheel spoked(yes I know its not pretty) but lessons learned and it can go on the side nearest the wall in the dio so wont be seen.
http://i.imgur.com/sgkrB2b.jpg
http://i.imgur.com/mNyyp6V.jpg
and here is some progress on the car
http://i.imgur.com/ATiTP9A.jpg
http://i.imgur.com/aSK4Csd.jpg
    March 2014
Posted by kpnuts on Wednesday, January 21, 2015 3:16 PM
Hi all here is tonight's bit. I have cut off the steering column (not my idea got it from stevieo) and replaced it with part of my extending mirror.
http://i.imgur.com/0ckVsVj.jpg
http://i.imgur.com/b1zhWh4.jpg
http://i.imgur.com/xTTEUfg.jpg
and here is more progress on the rest
http://i.imgur.com/j8g2O13.jpg
http://i.imgur.com/gefUblv.jpg
http://i.imgur.com/6UD18xn.jpg
http://i.imgur.com/ojvcdqs.jpg
http://i.imgur.com/XYr1LFb.jpg
http://i.imgur.com/WvcYKf2.jpg
I understand these car bodys were covered with cloth and am thinking of covering it with paper and painting that, do you think that would give a clothe effect finish.
    June 2010
Posted by OctaneOrange on Thursday, January 22, 2015 6:03 PM
i'd suggest you use tissue paper and white glue to get it to shape. once that's dry, you can paint it whatever colour you need.
    March 2014
Posted by kpnuts on Friday, January 23, 2015 2:43 PM
Hi all thanks to roymattblacks very nice and comprehensive pdf of this model I have decided to go with cloth covered body and here is my effort
http://i.imgur.com/ZgNrwTC.jpg
http://i.imgur.com/An3g9XL.jpg
http://i.imgur.com/HaS6kVp.jpg
    March 2014
Posted by kpnuts on Wednesday, February 4, 2015 2:04 PM
Well thanks for following along I dont see my boss's husband buying this now, and I've gone and taken a commission from my boss now I feel guilty now she's paid for the models and I've bought them but I've obviously not got the skills to deliver, I must have been mad to agree. I've ruined the Bentley , I will finish it but it certainly won't be on display anywhere.
http://i.imgur.com/SKZGVTb.jpg
http://i.imgur.com/piK5ePt.jpg
http://i.imgur.com/ptiIQY4.jpg
http://i.imgur.com/uMI8nIV.jpg
http://i.imgur.com/xpybey7.jpg
http://i.imgur.com/IWTTIqT.jpg
http://i.imgur.com/4yVrhlC.jpg
http://i.imgur.com/ymkrQFz.jpg
http://i.imgur.com/or8SxHi.jpg
http://i.imgur.com/h4NU20V.jpg
http://i.imgur.com/0NYvzmD.jpg
http://i.imgur.com/entol6m.jpg
These next three pics show whats gone wrong(yes I know I could get a new body from Airfix and some decals) but to be honest I cant be asked I've lost all interest in it now, I will finish it but just to say its done and get it out the way.
http://i.imgur.com/twHNgxP.jpg
http://i.imgur.com/e8EHHDP.jpg
http://i.imgur.com/lHqrWN4.jpg
    March 2014
Posted by kpnuts on Thursday, February 5, 2015 1:51 PM
Well I fixed it I filled my revell precision glue pot with super glue then I made a little hole in the air bubble and squeezed the superglue in the hole, then I gradually squeezed the excess glue and air out of the hole. I fixed the decals with a hair drier, I put it on maximum( I figured I had ruined the body anyway so nothing to loose) I heated the decals up then squeezed them flat with some tissue.
http://i.imgur.com/ZN98sM2.jpg
http://i.imgur.com/Wf4pjWz.jpg
http://i.imgur.com/rpbqeqE.jpg
    June 2010
Posted by OctaneOrange on Saturday, February 7, 2015 4:43 PM
Keep at it kpnuts, sometimes we look at our work with overly critical eyes. All you can do is work methodically and do the best you can. It'll work out in the end.
Looks quite good here. I notice the body looks kind of 'lumpy' or textured, is it supposed to look like a fiberglass body?
    August 2007
Posted by DUSTER on Sunday, February 8, 2015 5:28 PM
kpnuts
We all have had the "dream slip away" . So pack this thing up, hold it for a while and later, tackle it again.
You'll be surprised at how much you can accomplish, once you get a bit of distance from today.
As to your customer explain the situation, issue a refund and express how  grateful you would be if they would accept another attempt in future.
Regardless, you did rather well on many aspects of the build, so you're not without talent- this body part  just got away from you.
Model On brother, we are with you for your next work-in-progress
Steve
