My girlfriend drives a 1/1 1999 Toyota Corolla VE, and if there is a kit of it I would like to build it for her. So does anyone know if there is such a kit?
Thank you in advance.
---------------------------------Digital CowboyLive Long and ProsperOn the Bench: '64 Ford Fairlane; '09 Corvette Coupe
i don't think so. i call them "corolla-over"!
The only kit i know of is a much older 70s and 80s models.
My Photo Album
closest i've found is this
Thank you, I don't think that that would work as her's is a four-door.
You could kit-bash two together to make a four door version, if you can find a blueprint/CAD drawing or a good picture I'm sure you can use those as guides to extend it into a four door model!
Scratchbuilder725 You could kit-bash two together to make a four door version, if you can find a blueprint/CAD drawing or a good picture I'm sure you can use those as guides to extend it into a four door model!
Scratchbuilder,
Sadly, I’ve never kit bashed before. And as such I don’t think that that is something (your suggestion) that I could pull off.
You can always have someone design the car in a 3-D modelling program and have it printed, but that will probably be an investment.
Sadly,it is an expense that at this time I cannot afford.
