Painting Hawaiian Funny Car
    July 2009
Posted by Westpalm on Tuesday, September 29, 2015 11:21 AM
I filled in the roof line of the kit (where there was an optional roof hatch) and sanded it smooth to the surface. After Painting it blue it still shows this work evidence. I was considering stripping the paint back off with Castrol Super clean and priming it first. Will this eliminate the problem?
    August 2015
Posted by Arved on Tuesday, September 29, 2015 2:56 PM
You still have some work feathering the filler. After you strip, work on filling and sanding. Airbrush (or rattlecan - I always prefer airbrush) Mr. Surfacer 1000 as a primer. Then wet sand if necessary. Super fine grit with a backing. 1200 grit sandpaper wrapped around a 6" steel rule as an example. Depending on how much leveling your topcoat gives, you may have to "rinse and repeat" working up to 4000 grit sandpaper. On some models, I've "sanded" using Post-it note paper pads (dry).
Are you sure you don't need that escape hatch?
"Sixth is the roof escape hatch that is in place on all Funny Cars since the founding of the division in the early 1970s. This device allows Funny Car drivers a safe means of exit during an engine fire rather than falling out of the car between the frame and fiberglass body, and possibly running the risk of being run over by the rear tires." - Wikipedia
- Arved
e-mail | Blog
"Simplicate and Add Lightness" — design philosophy of Ed Heinemann, Douglas Aircraft
    September 2012
Posted by GMorrison on Tuesday, September 29, 2015 4:24 PM
Arved- that has to be about the most lurid wiki entry I've ever read!Surprise
    August 2015
Posted by Arved on Wednesday, September 30, 2015 9:00 AM
Still looking for a date the hatch was adopted, but I did find this:
"Perhaps his (Don Schumacher) most significant contribution to safety was his roof-mounted escape hatch, which has long been a mandatory requirement for every Funny Car." - NHRA Funny Car pioneer Schumacher welcomed into International Motorsports Hall of Fame
Don't you just love how modeling forces us to be historians? Big Smile
- Arved
e-mail | Blog
    July 2009
Posted by Westpalm on Thursday, October 1, 2015 3:35 PM
The hatch is not there for the Hawaiian. Its a two model mold. The hatch is there for the cha cha. A new issue though, I have had it soaking in the super clean for a day now and the paint is nit coming off. Another suggestion?
    August 2015
Posted by Arved on Sunday, October 11, 2015 3:59 PM
91% Isopropyl Alcohol is my go-to stripper. Failing that, Eazy-Off oven cleaner. Both safe for plastics.
%70 Isopropyl Alcohol won't do anything, but 91% will. Go figure. Sometimes harder to find 91%, but worth the trouble.
There are also commercial strippers for models. Chameleon is one brand that's popular. Testors also makes "ELO" - Easy Lift Off.
Good luck!
- Arved
e-mail | Blog
    July 2009
Posted by Westpalm on Tuesday, January 5, 2016 12:08 PM
I wound up going with the 91% alcohol. It got 90 percent of it off, enough for me to re-work it.
