2?'s, one, engine wiring/detailing.... two, what to do w/ this trunk???
Posted by Anonymous on Wednesday, March 17, 2004 5:05 PM
Okay, here's the situation, I'm building a 70 Monte Carlo for my neibhor, the kit is great and he's not the biggest model buff. So, after chopping the trunk, I wonder.... what should I put back here? Since my neibhor dosen't much care about the contents of the finished kit, I plan on..."taking" the kits extras. The lowriders hydraulic batteries and motors!!! Only problem, I want to keep the trunk open! So, what should I put in this gapping hole in my kit??? I thought about some scratchbuilt speakers, but does anyone have any other ideas???
Second, okay, I love the look of a "wired" engine, how can I do that???? I've seen it done on other models, but I'm not sure how to actually wire the engine!!! I've also seen the photoetched wiring tabs, and I can't get my hands on them due to lack of $ and time! Plus, I'll be using wiring from small toys and odds and ends for the cables, so please. If anyone can give me any input on how to wire an engine painlessly, I'd appriecate it!!!!! Thanks!Big Smile [:D]
    December 2003
Posted by Enzo_Man on Wednesday, March 17, 2004 11:00 PM
Sounds cool!! Speakers sound cool. Maybe make it an entertainment area. Put in a TV and a PS2. That may be overboard. But as for wiring. Radio-Shack has some very nice 30-guage (I think) wire. Perfect for ignition and some other goodies. You should use a pin-vise to make the holes for the wires in the distributor and where the sparkplugs are. Then find out the firing order and wire it. IMO super glue is best for this. One thing that is crucial is referance pics. Even if just the ignition is added it makes a great deal of difference. Hope this helps ya! If there's any other questions you know where to ask. Peace!
Aerodynamics is for people who can't build engines.
Posted by Anonymous on Friday, March 19, 2004 11:14 AM
Man...great questions...very similar to ones I had when I was bumping my auto modeling up to the "next level"
I like putting nos in the trunks of my cars. If you can't spring for a kit in resin or aluminum...I've occasionally used the end of pens. You'd have to do a little searching for find ones with the right curve/size. Then, building the details with a little styrene.
For speaker boxes, I've cut the shape out of little blocks of wood. Then, I bought some wire mesh at michael's. I use (again) those little metal rings that separate the two halves of a ballpoint pen to put a round edge on the speaker.
Carpet the trunk...I use paper tape from the first aid aisle. Then just paint over it whatever color you want. Cheaper than buying fancy flocking.
SO, on to engine wiring. I found the most efficent thing for me was buying an engine detailing kit from PSF hobbies. I bought it off ebay, but you can order it from them directly. It come with almost everything you could want...multiple colors of wire, braided lines, heater hoses, seatbelt material. Its about 17 bucks, but it totally paid off...you can use it for more than one model.
Also, if you get a hold of some books specifically based on modeling car details, I've found those very helpful for ideas. Try your library...or just glance through them at your hobby shop.
Good luck...I'm sure your neighbor will love whatever you do!
-jonathan
Posted by Anonymous on Wednesday, March 24, 2004 9:47 AM
Thanks for the imput, here's an update..... after failing at tring to drill out the starter, i just left it out all together and it looks fine! I drilled the hole, glued in th wires and then glued the other ends to the headers! It isn't perfect, but it looks close enough for my neibhor! I'm kind of sad to lose the kit, I've put alot of extra work in and it lloks good, I'll keep you updated!!!! Thanks, bye!
