Tamiya 1/24 Nissan R390 GT1 Finished.
    February 2006
Posted by DantheMan85 on Saturday, August 13, 2016 2:25 PM
This is my first auto build that I've finished, Tamiya's 1/24 Nissan R390 GT1 #24192. Having gained a lot of experience building armor and aircraft kits, I wanted to give another subject a try. So I picked this up at my local Hobbytown USA for $33.00 USD, and spent about three months building it. For this build I wanted to try and airbrush as much as I could, in the end it seemed to have taken forever. On the car body I use Model Master Gloss Black spray and Tamiya TS-49 Bright Red & Tamiya TS-29 Semi-Gloss Black on the bottom. I first used Tamiya Gloss Black but I later used Model Master because it had more of a mirror like shin. The red is not a bright as it should be, I applied the TS-49 over the gloss black which make it darker. I know that applying a bright color over gloss white is the better way to go but I forgot about that. All in all the fit quality was very good, there's a small gap at the top of the rear wind shield that I didn't catch till when I was airbrushing Future on. After the decals were on I airbrushed Tamiya X-22 clear, and then Future. I'm am happy with how this project turned out. My next auto build with be Tamiya's 1/20 Ferrari F2001, this will be my second attempt with it.
On my Work Bench: Tamiya Ford GT 1/24
Up Coming: ?
    October 2005
Posted by looper on Sunday, August 14, 2016 1:56 PM
good job Yes,  i think it came out really good.  i learned something from your post as well as far as how to layer paint.
i've had a ferrari f1 2001 in the closet for about 10 years or so along with the williams f1 kit.  i don't have the skills yet to build them the way i want to,  gotta practice some more.
Andy
    February 2006
Posted by DantheMan85 on Monday, August 15, 2016 10:06 AM
Thanks Looper. Looking back if I could redo something, I would have hand painted the engine compartment. Airbrushing all that took forever. The kit also came with pre-cut masks for the windshield's, the instructions had me place the masks on the inside, by doing that it give a nice smooth gloss finish.
I plan to do some testing with paint on a $20.00 revell car kit, in preparation for my next build the Ferrari F2001. First with using Model Master enamel white primer #2748 as a base for Tamiya TS-49 Bright Red, the primer is semi-gloss so I could think I would not have to apply a gloss white over the primer. The Bright Red should look nice and bright, in a total of two light coats.
Came across a video on youtube showing how a modeler built the Ferrari F2001 kit, it's in Japaneses but it shows how to assembly some of the tricky parts, and even airbrushing on carbon fiber on the suspension. Title of the video is, Plamo Tsukurou 1x11 Tamiya Ferrari F2001 enhanced.
Up Coming: ?
    October 2005
Posted by looper on Monday, August 15, 2016 1:41 PM
do you have any close ups of the engine?
i just watched that video, thanks for the heads up.  do you know what compounds he used to shine up the nose?
any pics of the first f2001 build?
thanks
Andy
    February 2006
Posted by DantheMan85 on Tuesday, August 16, 2016 9:20 AM
First up is pictures of the F1 car.
Here you can see the major sections.
Taking a note from armor building, I use masking tape rolled up to stick the bottom to the Tamiya jar, for easy holding for airbrushing.
 One coat of Model Master Acryl white primer #4622.
 One coat of Tamiya TS-49 Bright Red.
 For what ever reason, I airbrushed on X-7 Red.
To make painting easier, in getting into hard to reach places I disassembled the front and rear wings.
Unfortunately I don't have any pictures of the decals, most of them went on with little to no trouble. The big white decals you have to be careful with, they tear very easy. The reason why I don't have the car model any more is that when handling it, I dropped it on the work bench and the suspension shattered into pieces. Was going to rebuild it but that would have been a lot of work, so I decided just to get another one.
In the youtube video I'm guessing he's using a automotive product. That's another thing I'm going to test out on some scrap, using a automotive product to get more of a shine.
I'll post photo's of the Nissan GT engine later today. Cool
Up Coming: ?
    August 2015
Posted by crown r n7 on Tuesday, August 16, 2016 2:15 PM
very sharp
 Nick.
    February 2006
Posted by DantheMan85 on Tuesday, August 16, 2016 3:21 PM
Thanks Crown r n7.
Up Coming: ?
    February 2006
Posted by DantheMan85 on Wednesday, August 17, 2016 11:57 AM
Here's some work in progress photo's of the Nissan R390.
Tamiya's pre-cut masks fit the clear parts perfect.
Engine base and rear suspension.
Three coats of Model Master enamel gloss black spray.
Tamiya tape was used to mask for TS-49 Bright Red, this is where I should have airbrushed on gloss white to use as a base for Bright Red.
After about four coats of TS-49. Using 2000 grit sand paper I sanding down the edge line created by the tape.
Fully assembled engine and rear suspension.
Up Coming: ?
    May 2013
Posted by hogfanfs on Wednesday, August 17, 2016 12:53 PM
I really like it, Dan! Great job!
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    February 2006
Posted by DantheMan85 on Wednesday, August 17, 2016 1:30 PM
Thanks Hogfanfs.
Up Coming: ?
    October 2005
Posted by looper on Friday, August 19, 2016 12:11 AM
thank you so much for the pictures Bow Down .  your f2001 was looking really good, its a shame that incident happened Crying .
the r390 came out great,  sharp looking vehicle Cool .
Andy
    February 2006
Posted by DantheMan85 on Friday, August 19, 2016 7:43 PM
Thanks Looper, my pleasure.  Yeah I didn't like having to throw the Ferrari away. I learned a few things from it and should make my next one even better. I would say the Nissan R390 was a easier build.
Up Coming: ?
