round 2 model cars.
    March 2009
round 2 model cars.
Posted by armorbaran@gmail.com on Tuesday, December 6, 2016 6:46 PM
I ambasicly an armor guy but everyonce in a while I try to find my favorite car. This happens to be the corvair. The only I found was from amt  second round. I went together good to the point of painting.I found a great color of arctic blur from testors acrilic. I sprayed it with the first coat and that s when the trouble started. Big blotches of white bleed through. so I sanded it and tried again. Damn! if the same thing didn't happen. It can not be the paint because I used two different bottles. Just what type of palstic is used?Am I going to have to give this kit a bath in CLR?. I would be thankful for any positive enforcement.
    August 2014
Posted by goldhammer on Tuesday, December 6, 2016 6:58 PM
Sounds like time to strip it off, give it a bath with soapy water, rinse, dry.  Maybe a light going over with a fine scotch-brite then prime, scuff and see if that fixes the issue.
You didn't say what your prep was so that is not saying what your prep was is wrong, just and idea on fixes.
I've got a round 2 Avanti that I haven't dug into yet, so am interested in if the above, or whatever, works out.
    April 2013
Posted by KnightTemplar5150 on Tuesday, December 6, 2016 10:33 PM
Some, but not all, of Round 2's kits have an awful lot of  mold release contaminating the surface. It seems to be particularly bad on larger pieces, especially with the white plastic. Soap and water seems to be ineffective for me, so I've taken to soaking the parts in Purple Power or Simply Green to degrease the parts before assembly.
    June 2014
Posted by Tanker - Builder on Wednesday, December 7, 2016 10:15 AM
Hi;
    Usually I've had no problem . But ,  just to make sure I surface prep any model with the thinner recommended for the paint . Something like taking a tack rag over it .
 I also use a tack cloth but , I have found if you are using one , do not press hard when you use it on plastic or primer .The material in tack cloths can cause what I call frost spots and fisheyes.      T.B.
