Tamiya 1/20 Ferrari F2001 (Finished)
    February 2006
Posted by DantheMan85 on Tuesday, May 9, 2017 10:58 AM
  1 by Daniel Smith, on Flickr
 3 by Daniel Smith, on Flickr
 2 by Daniel Smith, on Flickr
 4 by Daniel Smith, on Flickr
 9 by Daniel Smith, on Flickr
This is a work in progress build of Tamiya's 1/20 Ferrari F2001 Formula 1 car, kit number is #20052, retails for $41.00 USD. Released in 2002. This is my second attempt, was close to finishing the first one but ended up dropping it on the floor.
The kit contains 131 plastic, four rubber tires, two decals sheets, one metal foil, and one metal transfers. After watching a few Formula 1 build's on youtube, I'm taking a different approach to painting and assembling, than my first Formula 1 car. In the end it will make painting and finishing a lot easier.
 7 by Daniel Smith, on Flickr
 8 by Daniel Smith, on Flickr
First up is cutting out the parts from the sprue, some are left attached to make it easier. Then clean up the mold seams, fill in injector holes. I start off with 800 grit sand paper, 400 is only used it needed. Then from 800, to 1000, then 1500 and to finish off with 2000. I found that wet sanding leave's a smoother finish then using the paper dry.
 10 by Daniel Smith, on Flickr
More to come. Cool
On my Work Bench: Tamiya Ford GT 1/24
Up Coming: ?
    February 2006
Posted by DantheMan85 on Thursday, May 11, 2017 9:59 PM
Here's most of the parts that need to be filled in.
 15 by Daniel Smith, on Flickr
 16 by Daniel Smith, on Flickr
To Remove the mold seam and give the tires a worn look I sanded them down with 400 grit sand paper. The tires used during the FIA Formula 1 2001 season had groves in them. Tamiya painted on the Bridgestone & Potenza logo's.
 18 by Daniel Smith, on Flickr
Here's all of the parts after washing them with soap and water.
 20 by Daniel Smith, on Flickr
Every part is attached to a tooth pick or to a pop sickle stick, for easy handily for airbrushing or spray can.
 21 by Daniel Smith, on Flickr
 22 by Daniel Smith, on Flickr
The parts to be painted TS-49 Bright Red, after filling and sanding I primed them up with Model Master Gray Primer #2737. A good coat of X-2 White is next up.
 25 by Daniel Smith, on Flickr
 26 by Daniel Smith, on Flickr
 27 by Daniel Smith, on Flickr
 29 by Daniel Smith, on Flickr
 31 by Daniel Smith, on Flickr
Using TS-30 Silver Leaf I sprayed the engine radiators, then sealed in the metal color with Testors Gloss Coat. Normal metal colors don't have to be sealed in with a clear or gloss coat, when masking over them the tape peals off metal powder. By sealing them in this reduces the powder peal.
 36 by Daniel Smith, on Flickr
 37 by Daniel Smith, on Flickr
Last year I decaned Tamiya's TS-49 Bright Red, so to help use it up I airbrushed on the first coats on to the parts. As it turned out, decanning that TS-49 it removed the gloss from the paint. The parts had a flat to semi-gloss feel to them.
 32 by Daniel Smith, on Flickr
 33 by Daniel Smith, on Flickr
 34 by Daniel Smith, on Flickr
The Front wing was at first a little tricky holding so I CA glued on tooth picks on the side. The bottom is X-1 Black, the top is TS-49. There are white decals to be put on the top but, I'll be painting it instead X-2 White.
 38 by Daniel Smith, on Flickr
 39 by Daniel Smith, on Flickr
To help speed up spraying I taped the parts to balsa wood strips, then taped on plastic spures that fit into Tamiya's turn table holder. The parts below now have four coats of TS-49 Bright Red. The monocoque is really looking good.
 41 by Daniel Smith, on Flickr
 43 by Daniel Smith, on Flickr
Up Coming: ?
    February 2006
Posted by DantheMan85 on Wednesday, July 26, 2017 5:00 PM
Finally finished the Ferrari F2001, but first here's some construction photo's.
 50 by Daniel Smith, on Flickr
 55 by Daniel Smith, on Flickr
 59 by Daniel Smith, on Flickr
 61 by Daniel Smith, on Flickr
 64 by Daniel Smith, on Flickr
 67 by Daniel Smith, on Flickr
Up Coming: ?
    February 2006
Posted by DantheMan85 on Wednesday, July 26, 2017 5:37 PM
And now for the finished model. I was going for perfection but it didn't work out they way, I'm happy with the end result. Learned a lot about building open wheel race car models, and using Tamiya's lacquer paints. Some parts had to be stripped down to the bare plastic and repainted which seemed to take forever, the Tamiya lacquer paint does not like to be masked over for some reason, even giving it three or more days to cure. The kit itself is great, not that many parts, the real time eater is painting. The large white decals can be tricky to work with, and as you can see the rear engine cowling does not fit right.
 73 by Daniel Smith, on Flickr
 77 by Daniel Smith, on Flickr
 76 by Daniel Smith, on Flickr
 78 by Daniel Smith, on Flickr
 83 by Daniel Smith, on Flickr
 86 by Daniel Smith, on Flickr
 88 by Daniel Smith, on Flickr
 93 by Daniel Smith, on Flickr
 95 by Daniel Smith, on Flickr
Thanks for checking out my Ferrari F2001 build. Smile
Up Coming: ?
