Buffing out a spec of dust after wet coat?
    February 2006
Posted by Wilbur Wright on Monday, June 5, 2017 9:52 PM
Guys I have sprayed my Ferrari 308 model Testors Italian Red enamel.  Two mist coats one wet coat.  I then had two dust specs on the hood.  I tried the Tamiya polish and it really didn't work so I sanded the dust off and did another wet coat on the hood.   Now I have two more specs of dust in an otherwise nice paint job.
Any ideas what I should use to get rid of the specs of dust?   The paint is a nice high gloss red and I hate to buff down the gloss in any way.  I have the Tamiya polishes and sand paper up to 12,000.
Any advice is appreciated
Thanks
    August 2015
Posted by crown r n7 on Tuesday, June 6, 2017 7:54 AM
I have tried to remove dust specs for the longest time . If you have enough base coats under wet coats you could try to lightly sand out spec and polish if not remove the paint and start again since its not metalic color repaint the hood.
 Nick.
    January 2003
Posted by leemitcheltree on Wednesday, June 7, 2017 5:44 PM
Wilbur...gotta say...NOVUS makes an OUTSTANDING polishing kit for models.
Their 7100 Plastic Polishing Kit is....WICKED.  Their No. 2 fine scratrch remover, followed by their No.1 Plastic Clean and Shine is the bee's knees.  Seriously.
Give it a go.....I absolutely recommend it.  And....I do NOT work for NOVUS.  Just someone who has used the products.....and have been impressed.
Cheers, LeeTree
Remember, Safety Fast!!!
    September 2012
Posted by GMorrison on Wednesday, June 7, 2017 5:46 PM
3 ounces of Bourbon, straight.
Posted by Don Stauffer on Thursday, June 8, 2017 8:55 AM
I have successfully taken care of a few dust specks by overcoating with clearcoat after a fine sandpaper.  You may find it easier to get a dustless finish with the clearcoat than with color.  Also, try to clean up your spray area before spraying those final coats.  Also, I know some folks who spray water in the air just before they spray.  Higher humidity reduces dust.
    March 2017
Posted by treehuggerdave on Thursday, June 8, 2017 8:15 PM
Don Stauffer
I agree with Don. The clear acts as a barrier coat to finish especially on metallics
 All my enamels I clear coat with acrylic lacquer clear.
Yeah I know everyone says you can't, but been doing it for a dozen years with great results.
Good luck on your project.
Phil. 4:6-7   Jer. 29:11-14  John 3:13
On the bench - Hand made '50 Lincoln "Tail dragger"  1956 DeSoto 'vert., Resin '60 Chrysler 300 , Modelhaus resin '58 Pontiac hardtop kit.
Been a "Plastholic" all my life. Love this stuff.
    February 2006
Posted by Wilbur Wright on Thursday, June 8, 2017 10:55 PM
I can report that I have succesfully removed the 3 dust specs by using a runout of the Tamiya Polishing compounds...  course then fine then finish.    They really work, although it took about an hour at the sink to do the whole car.  Rinsing off thoroughly after each level of compound.
  The thing looks  closer to  real car paint than I have ever done before.  I guess I had the enamel on thick enough to do this, two mist-two wet coats.  Metallics would not have been as forgiving as the opaque Italian Red.
I agree with Don that the cleanliness of your paint area is pivotal in avoiding dust.  Water misting is a good idea.  When I built my giant Revell B-36 model I built a temp spray booth by hanging  4 mill clear poly from HD, floor to ceiling about 8' high x 5' x 5' .  My model room is in the cellar.   It worked well.   I'm thinking of doing that again and leaving it up
I'll post photos when I'm done with the 308
Thanks,  Men
