- Member since
January 2007
Posted by fox
on Wednesday, October 7, 2020 2:41 PM
My for what it's worth. I have not had that problem here maybe because the humidity is around 50%. When the humidity gets below that, you get a lot of static electricity. You can use a small difuser, the kind they use with esential oils to make a room smell better. It puts out a continuous small spray of water and oils but you can leave out the oils and just use water to put a little moisture into the air. My wife is into those oils, that's how I know about them. She has a couple of them going all the time.
Hope that this helps.
Jim
Stay Safe.
Main WIP:
On the Bench: Artesania Latina (aka) Artists in the Latrine 1/75 Bluenose II
