Senna McLaren [FINISHED 4-30-21]
    October 2020
Posted by Scale-Master on Friday, April 9, 2021 7:39 PM
I'm building this one straight out of the box, but changing up the colors (compared to the instruction call outs) to match some versions I found online.
First up was to paint the single piece monocoque semi-gloss black then gloss black for the cockpit area.  I used TS-29 and LP-1.
Build what you want and build it for yourself, the rest will follow... Mark D. Jones
    October 2020
Posted by Scale-Master on Sunday, April 18, 2021 8:21 PM
The LP-1 Black (thinned with Tamiya lacquer thinner) checked and crazed over the TS-29 as it dried overnight.  (The TS-29 was shot 24 hours before the Gloss Black.)  Not the first time I've used this paint, but the first time something less than good resulted.
So I sanded it out and reshot with decanted TS-14 and had no adverse reaction.
    January 2020
Posted by wpwar11 on Sunday, April 18, 2021 9:07 PM
I hear this is a great kit.  We're coming up to May 1.  The day legendary racer Aryton Senna lost his life at Imola.  Good luck with your build.
    October 2020
Posted by Scale-Master on Monday, April 19, 2021 10:58 AM
The parts and molding would suggest it's a great kit.  So far the fit does too...
I also painted the other gloss black body parts at the same time I repainted the roof section.
Posted by keavdog on Monday, April 19, 2021 7:16 PM
Nice save on the paint.  I'll be following along - considering this kit for the stash Cool
Thanks,
John
    October 2020
Posted by Scale-Master on Tuesday, April 20, 2021 9:11 PM
These are the body parts that will be shot white.  (I'm doing the end plates of the rear spoiler in the accent color.)
    July 2008
Posted by jeffpez on Wednesday, April 21, 2021 7:01 AM
I'm looking forward to you completing this build because I'm having a significant problem with mine and want to see how you solve it. I'm trying to insert the finished chasis/interior into the body and can't get it to fit. It gets about 3/4 in and then is hung up somewhere but I can't figure out where. The sides of the body need to be spread, as the instructions show, but it won't give enough for everything to fit. I've had several parts fall off from the strain and hear cracking sounds but it won't go. I'm packing it up and will wait until you get to this point. Other than that everything fit well and I loved the kit.
    October 2020
Posted by Scale-Master on Wednesday, April 21, 2021 7:03 PM
I'll pay attention to that Jeff and let you know if I see something.
The calipers are called out to be the same color as the body accent pieces, but I thought the photos of the real car in the instructions indicated otherwise.  I liked the anodized look so I used TS-54, TS-17 and TS-72 to get close enough.
    October 2020
Posted by Scale-Master on Thursday, April 22, 2021 12:27 PM
The engine is engineered "without parts count escalating excessively", and I'm sure when it's under the glass it will look fine.
    October 2020
Posted by Scale-Master on Saturday, April 24, 2021 2:58 PM
I have completed steps 1 and 2…
    July 2014
Posted by Bakster on Saturday, April 24, 2021 4:43 PM
keavdog
Ditto
    October 2020
Posted by Scale-Master on Saturday, April 24, 2021 7:43 PM
I started painting the seats to match the photos of a real one I found.  TS-53 and TS-23 both mixed with Dullcote.
    July 2014
Posted by Bakster on Saturday, April 24, 2021 11:23 PM
The seats look gorgeous.
    October 2020
Posted by Scale-Master on Sunday, April 25, 2021 6:35 PM
Thanks!
The chassis builds up very quickly once all the painting is done.  The fit is still excellent so far.
I went the accent color for the parking brake calipers.
    October 2020
Posted by Scale-Master on Sunday, April 25, 2021 7:05 PM
Dash…
    October 2020
Posted by Scale-Master on Monday, April 26, 2021 12:48 PM
The wheels got some blue too.
    October 2020
Posted by Scale-Master on Monday, April 26, 2021 7:05 PM
The dash with the steering wheel and display is installed.
The door panels are done, the exterior accent color was used on the struts.
    October 2020
Posted by Scale-Master on Monday, April 26, 2021 7:20 PM
The interior is done.
    October 2020
Posted by Scale-Master on Monday, April 26, 2021 8:47 PM
Before I added the roof and glass parts I test fitted this assembly over the chassis/interior.  It fell into place easily (and was a lot harder to remove than install).
I used the LP Smoke paint for the top glass pieces.  It says not to cement these clear parts in, and can be assembled without any, but I used a few tiny drops of canopy glue at the locating tabs just to keep them in place until the center section was installed to lock them to the car.
    July 2014
Posted by Bakster on Monday, April 26, 2021 11:32 PM
Very very cool. Model is looking awesome and great progress.
    July 2008
Posted by jeffpez on Tuesday, April 27, 2021 2:02 PM
I'd previously mentioned that I couldn't get the finished body and chasis to fit together so I set them aside and went on to something else. After reading that you had no problems I picked up mine and it simply popped together with ease. I don't know why I had trouble and don't know why this time I didn't but I'm more than happy with the result. Now I can finish it.
    October 2020
Posted by Scale-Master on Tuesday, April 27, 2021 2:03 PM
That's awesome Jeff!
    October 2020
The glass is in except for the lower door windows.  Beautifully engineered to fit and trap the glass in place.
    October 2020
Posted by Scale-Master on Wednesday, April 28, 2021 4:33 PM
The parts fit continues to impress.
    October 2020
Posted by Scale-Master on Wednesday, April 28, 2021 6:40 PM
The headlights are designed to go together very cleanly.
    October 2020
Posted by Scale-Master on Wednesday, April 28, 2021 8:23 PM
More well-fitting body parts…
    October 2020
Posted by Scale-Master on Thursday, April 29, 2021 12:54 PM
The glass and body panels are all installed.
The engine/chassis is done too.
    May 2011
Posted by Mr Mike on Friday, April 30, 2021 7:50 AM
I have been watching this build from afar and I like the quality that you are putting into this build.  Excellent!
    October 2020
Posted by Scale-Master on Friday, April 30, 2021 3:50 PM
Thanks Mike!  Highly recommendable kit!
    October 2020
Posted by Scale-Master on Friday, April 30, 2021 3:51 PM
All Finished.
Amazing engineering.  Excellent kit!
