A beginner's guide to building plastic model cars
Moderator
    September 2011
Posted by Tim Kidwell on Monday, May 22, 2023 12:23 PM
If you're new to building plastic model car kits, search no further! Click this link and let FineScale Modeler help you get off the starting line, including an overview of tools and techniques to immediately improve your scale modeling experience.
Timothy Kidwell
tkidwell@firecrown.com
Editor
Scale Model Brands
Firecrown Media
    May 2004
Posted by cbaltrin on Tuesday, May 23, 2023 6:01 AM
Thanks.  These articles are always ineresting, even for old salty modelers.
On the Bench: Too Much
    April 2005
Posted by BigJim on Tuesday, May 23, 2023 3:22 PM
I got to the following statement and said "WHOA"!!!
"Liquid plastic cement works best on unpainted styrene. It’s easy to use: squeeze the parts between your fingers that are being glued, collect a generous amount of liquid glue with the in-cap applicator, and touch the applicator to the joint. Capillary action will pull the cement into the joint. Within 20 seconds, the parts will be joined."
Folks you are just asking for trouble when doing this! Be VERY careful where you place your fingers as the "Capillary" action can (and will) sneak under your fingertips and ruin the plastic that you are holding together!
    April 2020
Posted by Eaglecash867 on Wednesday, May 24, 2023 7:03 AM
"It’s easy to use: squeeze the parts between your fingers that are being glued, collect a generous amount of liquid glue with the in-cap applicator, and touch the applicator to the joint. Capillary action will pull the cement into the joint. Within 20 seconds, the parts will be joined."
Just to throw my 2 cents in on this as well:  This technique works a lot better if you leave a tiny gap between the two parts before touching the applicator to the joint.  Continue to hold the parts just slightly apart for that 20 seconds, and then press them together to get a nice, even little bead of melted plastic to ooze from the joint.  That little gap gives the cement a place to hang out so it doesn't immediately evaporate before its able to fully do its job.
You can also adjust the alignment of the parts while the plastic is still soft to get panel lines lined up and make sure you don't have a step between the parts.  After 24 hours (or at least overnight to let the plastic fully re-harden), I gently sand the joint with progressively finer grits of MicroMesh and am able to eliminate a majority of any visible seam between the parts.
Speaking of seams.  CA is a much better way to fill seams and gaps than using putty.  Just put a very tiny amount of CA in the gap with a toothpick and let that cure overnight.  Then take a Fine Point Sharpie and scribble along the cured bead of CA.  Gently wet sand the blackened bead, following the curvature of the joint, until all of the black sharpie is gone.  Prime it to check how succsessful you were with filling the gap, and about 95% of the time the seam will be completely eliminated on the first try.  No putty, sand, repeat dance...and no orange, green, or white dust all over everything.  The other good thing about the CA method is that if you did miss a tiny gap here and there, you can dab a little more on the spots you missed, right over the top of the primer.  If you dab it on and leave it alone overnight, the primer and CA will have mixed and become one.  Can't do that with solvent-based putties either.  I use the same technique for filling pin marks.  CA also can be scribed without cracking, chipping, or coming loose, so re-scribing across the joint is much easier than trying the same thing with putty.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
Moderator
    September 2011
Posted by Tim Kidwell on Wednesday, May 24, 2023 8:48 AM
BigJim
Thanks for the comment, Jim. Thin cement works via capillary action--the glue is drawn into the join or seam between the parts. You make a good point that modelers should be aware and careful of how they're holding parts when gluing (no matter the glue they're using) and painting.
We go into more detail about using various glues on models in this Scale Model Basics video, Glues and How To Use Them.
Timothy Kidwell
Editor
Scale Model Brands
Firecrown Media
Moderator
    September 2011
Posted by Tim Kidwell on Wednesday, May 24, 2023 8:55 AM
Eaglecash867
Good stuff, Eagle. Superglue (also known as cyanoacrylate or CA for short) can definitely be useful as a filler. My only caution is that superglue, when fully cured, is harder than the surrounding plastic. Be sure to sand before it has hardened completely to avoid possibly deforming the plastic around the superglue.
We go through using superglue as a filler in our Scale Model Basics video, "How to fill gaps and seams on scale plastic models."
Timothy Kidwell
Editor
Scale Model Brands
Firecrown Media
Moderator
    September 2011
Posted by Tim Kidwell on Wednesday, May 24, 2023 8:56 AM
cbaltrin
Thanks! We like having the basics out there to help anyone and everyone.
Timothy Kidwell
Editor
Scale Model Brands
Firecrown Media
    April 2020
Posted by Eaglecash867 on Wednesday, May 24, 2023 12:56 PM
Tim Kidwell
I always sand it fully hardened, using the steps in my post.  The Sharpie indicator keeps you from over-sanding.  I think the deformation comes in when trying to sand it before its fully hardened...its hard to gauge what's what when its not fully hardened.  I think a lot of problems using CA also arise from people wanting to use fillers in the CA, which makes it really difficult to sand.  I also tend to avoid using any kind of accelerator on CA when filling seams, which also leads to overly-hardened CA that is jagged.  Used all by itself, and given sufficient time to cure, the process is practically fool-proof.
Moderator
    September 2011
Posted by Tim Kidwell on Wednesday, May 24, 2023 1:01 PM
Eaglecash867
I always sand it fully hardened, using the steps in my post.  The Sharpie indicator keeps you from over-sanding.  I think the deformation comes in when trying to sand it before its fully hardened...its hard to gauge what's what when its not fully hardened.  I think a lot of problems using CA also arise from people wanting to use fillers in the CA, which makes it really difficult to sand.  Used all by itself, and given sufficient time to cure, the process is practically fool-proof.
YMMV. Glad it works for you, and the Sharpie guide is a good tip.
Timothy Kidwell
Editor
Scale Model Brands
Firecrown Media
    April 2023
Posted by ctruss53 on Thursday, May 25, 2023 7:49 AM
BigJim
That process is exactly what some of those glues are designed for.  Tamiya thin cement with the green cap for example, is intended to be used this way. I love that stuff.
I also use it on small clear parts like headlight and tail light lenses. You can place the piece where it needs to go and then wick the glue in around the edges.
Insert wise quote here.
-Chad
