Interior Paint
    June 2004
Interior Paint
Posted by nicevillescott on Monday, June 28, 2004 11:59 AM
What's the best paint to use on the interior of car models? Gloss, flat, semi-gloss, enamel or acrylic? Any help would be appreciated. Thanks.
    September 2003
Posted by mojodoctor on Monday, June 28, 2004 12:16 PM
Yes!
Well, that's the simple answer. All of the paints mentioned will work where appropriate. Some leather upholstery looks good with a stain finish, some vinyl looks good with a semi-gloss, carpet looks best with a flat, some dash detail is best with high gloss,.......
A good mix of finishes really brings out the detail for an interior. As far as acrylic or enamel, look around this forum for a ton of opinions about the virtues of each paint.
Whatever you do, practice and find what works best with you. Have fun!
Matt Fly fast, fly low, turn left!
    June 2004
Posted by hct728 on Monday, June 28, 2004 9:37 PM
I find that semi-gloss works well for me, I can rub it here and there to gloss it a bit to make it look more realistic. Two coats (minimum) are recommended. Often primer works well for a grey interior, too.
