a word on hot rivit , what I do for hot rivit is to heat up the tip of a small regular screw driver with a lighter and mush down the top of the pin so it won't fall back down through the hole , but don't go crazy , because you want the front wneels to swivel to look like they are stearing,
um the engine I think is a Cummins which can be tan for older or red more modern engine,
to see some of the best model trucks on the www go to plasticcowbow.com
