I need to remove A LOT of orange peel from my first ever model!!
Posted by Anonymous on Monday, July 19, 2004 3:31 PM
Hello, im new to modeling, and i just finished painting my first model, a 1970 Chevelle SS454. Te problem is that i got plenty of orange peelDead [xx(], and i want to know how to remove it once the paint dries. The finest grit sandpaper i have is 1500, and i cant get anything finer in my area. Any help would be greatly appreciatedBig Smile [:D]!
Thanks,
-Shalin
    July 2003
Posted by lizardqing on Monday, July 19, 2004 4:27 PM
Welcome to the forum and the hobby. The only answer I know of if it is very bad is stripping it and trying it again. But then I have always had bad luck with orang peel myself. Hopefully someone else will have a better solution.
Posted by Anonymous on Monday, July 19, 2004 4:40 PM
i dont think its bad enough to have to strip the paint, i think i can sand it, but will 1500 be fine enough, followed by rubbing compound and wax?
    July 2004
Posted by Vinnietbird on Monday, July 19, 2004 4:43 PM
Start by wet sanding with 1000 or 1500 grit,move up to 2000,or finer..clear coat it,sand again carefully (wet),and polish it.
Posted by Anonymous on Monday, July 19, 2004 4:54 PM
The hobby places in my area dont carry anything finer than 1500, so i cant get anything else! Sad [:(]Banged Head [banghead]
    July 2003
Posted by Model Grandpa on Monday, July 19, 2004 5:11 PM
Check with the stores that sell auto paint and supplies in your area, they may have finer sandpaper for you.
Regards, Dan Building Scale Models At The Speed Of Dark
    June 2003
Posted by M1abramsRules on Monday, July 19, 2004 6:16 PM
check the hardware stores too.
Posted by Anonymous on Monday, July 19, 2004 6:29 PM
I checked all the auto and hardware stores today, and i couldnt find anything finer than 1500Grumpy [|(] !! Can i still get a good finish with 1500 grit, or am i screwed?
Sigh [sigh]
Thanks for all of the replies guys, keep sendin em in! Bow [bow]
    January 2004
Posted by mkhoot on Monday, July 19, 2004 10:43 PM
Here is a place that sells micro mesh kits they work great starts at 1500 grit and gets finer. http://www.simcom.on.ca/woodbin/MicroMeshProducts.htm
When in doubt just build it. Mark http://www.ipmslivonia.org/ipms/
    July 2004
Posted by Vinnietbird on Monday, July 19, 2004 11:12 PM
You can use the white sheet and the red sheet of sand paper in theTestors model car sandpaper pack from any hobby shop,or Wal-Mart.Plus,it's cheaper than auto sandpaper.
Posted by Anonymous on Monday, July 19, 2004 11:38 PM
You can still get pretty good shine without a full polishing kit. I'd suggest wet-sanding up to the 1500 grit (watch the corners and edges very carefully though - actually, I'd suggest putting a thin strip of masking tape over all of the edges/corners to prevent sanding through the paint.) Then, you could use some paste-type polishing compound (not wax) on it. Tamiya sells some, or you might try some of the automotive stuff (Turtle Wax brand, 3M brand, etc... check the automotive section of Walmart)
After that, you may want to shoot it with clear coat for a final 'shine'...
Murray
    September 2003
Posted by nicholma on Wednesday, July 21, 2004 3:46 AM
You could also use a piece of well used 1500 paper. That will significantly reduce the potential for deeper scratches etc.
Kia ora, Mark "Time flies like the wind, fruit flies like bananas"
Posted by Anonymous on Tuesday, July 27, 2004 8:41 AM
Yeah put away the misery! Just strip the paint! And try again, again, and again till you are satisfied! Trust me. Later on when you got the feel, and when your paint jobs look good. You will appreciate it most!
Cheers!
    May 2004
Posted by Colin Russell on Friday, July 30, 2004 9:01 AM
The other option is to remove everything by stripping the paint completely. In the UK, there is a product called Mr. Muscle Oven Cleaner. Although not designed for models, it will completely strip off paint, varnish, decals - the lot - without damaging the plastic. Apply it to the model, seal the model in a plastic bag and let the chemicals do their work. After a few hours, take the model out - wear gloves - and wash it under running water. The whole lot should rinse away leaving an undamaged plastic model.
I would suggest trying it out on something old first, but I have heard it works extremely well.
Hope this helps.
    July 2003
Posted by zokissima on Friday, July 30, 2004 9:13 AM
Try your local plumbing stores, or home improvement stores. Even a place like Michaels, or similar art/craft store.
    December 2009
Posted by wildwilliam on Friday, July 30, 2004 11:49 AM
shalin,
when you say you checked 'auto stores' do you mean like autozone & pep boys?
what you really need is a bodyshop or a place that supplies bodyshops.
if you are in SoCal, there should be some around!
Posted by Anonymous on Friday, July 30, 2004 1:38 PM
I regularly get 1500 and 2000 grit from a couple of my local hobby shops. And I'm in Phoenix! If you're in SoCal, you should be able to find something, somewhere. Grab the Yellow Pages and let your finger do the walking!
