newbie in model autos
Posted by Anonymous on Friday, August 6, 2004 11:41 AM
Hi, I just bought my first auto models and its an academy 289 ac cobra in 1/24 scale and would like to ask you fellas as to any tips and building sequence. Also, what do you use in painting your autos, airbrush or rattle can? Do you also polish your models after painting?
Posted by dubix88 on Friday, August 6, 2004 12:44 PM
HEY,
Airbrushes are better, but lots of people use rattle cans. We usually have clear coat to put over the paint. But seriously, do a search, look at some of the threads in this forum, and check out scale auto. There is just so much, even a basic search would give ya alot of stuff.
Randy
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
Posted by Anonymous on Friday, August 6, 2004 4:23 PM
i use an airbrush on the exterior, i prefer Boyds enamel paint. for the interior i use a rattle can, preferably tamiya. one other thing i have found useful for making professional results is to airbrush or spraypaint everything. brushpainting usually does a sloppy job for me. if masking is involved i use tamiya tape, alot of guys recommended it to me and it truly works great. for polishing a car, i have heard to use real car wax, the fine scratch remover, or novus. i have yet to use them but they are highly recommended by some. i usulally finish off with a spray of future to even out all the decals. hopes this helps and good luck. i think you will enjoy autos, i made a swith from armor a while ago and now i wish i would of never bought any armor stuff!
    September 2003
Posted by nicholma on Friday, August 6, 2004 9:06 PM
Sigman, just follow the instructions that is usually a good build sequence. However having said that I always prefer to start with the body and get it painted and put aside so the top coat has as long to harden as possible. Its really no different to any other type of modelling so the skills you bring from other genre are just as applicable here. Keep reading this forum you'll pick up heaps of tips. Post photos as you build, we like to see how things are progressing
Kia ora, Mark "Time flies like the wind, fruit flies like bananas"
Posted by Anonymous on Saturday, August 7, 2004 1:09 AM
Thanks for the tips guys, really appreciate it.
Posted by Anonymous on Saturday, August 7, 2004 10:47 AM
I usually spray aerosol paint into a cup then shoot it through my airbrush. The aerosol paint is cheaper per fl.oz (ml) than hobby paint. And the companies produce car colors; metallics, pearls, stocks.
Posted by Anonymous on Monday, August 9, 2004 6:51 AM
Progress on my first scale auto: This is the first time of using a tamiya rattlecan. The paint is really nice and shiny but there's a portion that the paint run and some bubbles. How can i correct this? Should I sand the portion only or the whole part? Any tips?
Posted by Anonymous on Monday, August 9, 2004 9:23 PM
Sigman,
Sounds like you were moving too slow and maybe too close to the model. The result was a coat that was too thick and heavy. Remember, we live in a world of gravity. Interesting that no one actually knows what it is, but agree that it exists and can measure it in various ways, even developed units of measurement.
Anyway, out-smart Gravity by moving the can faster and about 8" - 10" (20.32cm - 25.4cm) away from the model surface. Start spraying before the model and end after the model. You'll get thinner and lighter coats that way. In fact, the first coat should look like a misting and you'll see the plastic. Practice on a scrap.
For sanding the already painted model: you won't need to sand the whole model. Sand the area affected with the 'sag' and a little outside that area. First Wait until about 36 hours after you painted it so it will 'cure'. May I suggest wet sanding that area with 'dry/wet' sand paper of 600 grit first then follow with 800 then 1000 or more.
Well, have fun ! (the most important suggestion)Clown [:o)]
Posted by dubix88 on Tuesday, August 10, 2004 5:20 AM
HEY,
Next time, do what he said, but also use a primer if you didnt. I also usually san between each coat, but you only really have to sand between the clear coats, but i figure. y not.lol Like he said, have fun, thats why we do this.
Randy
Posted by Anonymous on Wednesday, August 11, 2004 8:56 AM
Thanks for the tips Ako Sprue. I spray my model about 6" away and i think this cause the paint to run. I will try it a little bit farther on my next coating.
dubix88, i always wanted to use primer but I don't know how to use one using rattlecan. Any tips? Also, it is very hard to source a primer for scale modeling in our area.
Posted by Anonymous on Wednesday, August 11, 2004 3:17 PM
Hey Sigman check out this link, it should help guide you through the painting process.
http://italianhorses.net/Tutorials/PerfectPaint/paint.htm
Posted by Anonymous on Friday, August 13, 2004 8:17 AM
Thanks for the link caseyn5
Posted by Anonymous on Friday, August 13, 2004 6:15 PM
no problem, and good luck with that cobra.
