SUGGESTION PLEASE
SUGGESTION PLEASE
Posted by Anonymous on Tuesday, April 22, 2003 6:38 PM
I HAVE A BEAUTIFIL 69 SHELBY IM WORKING ON I HAVE TO PAINT IT SILVER METALLIC I USE ACRYLIC TESTOR SPRAY CANS BUT I HAVE A HARD TIME GETTING THE FINISH I WANT ANY IDEAS ON WHAT I SHOULD DO FROM NOW ON SO I CAN BE PROUD OF MY WORK. ALSO SOME ONE SAID SOMETHING ABOUT FUTURE FLOOR POLISH TO BE USED AS A CLEAR COAT GLOSS EFFECT WILL THAT WORK ON OLDER MODELS IVE DONE TO SHINE THEM UP PLEASE GIVE ME SOME IDEAS SO I CAN PAINT LIKE A PRO
Posted by Anonymous on Tuesday, April 22, 2003 6:46 PM
you can read this topic.
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=2488
for example.
And there more messages about this topic an the forum.
    January 2003
Posted by leemitcheltree on Saturday, April 26, 2003 7:07 AM
Deano, do you have an airbrush? If not, and you're using spray cans, refer to the FSM article on spray painting with cans. Use a good quality paint, heat it thoroughly and carefully in a pan of warm water, and dust the color over your primed car body. After a couple of light dusting coats, hit it with a wet coat.
It never hurts to practice on a scrap car body if you have one, or try the technique on a tin can first. If you use a good quality gloss paint you wont need the Future clear coat. I usually use future to gloss up flat paints or as a clear sealing coat over decals, such as on an airliner.
Good luck.
Cheers, LeeTree
Remember, Safety Fast!!!
